hmmm... interesting...
could it have been that I just posted Holdens_r_better because I was chatting to him at the time? Hmmm... oh well
Hey and that chatting to me about prices is for real too... and open to anyone because I can tell you exactly what it takes to build a 13 sec car for a $2000 mods budget..... it would be even easier if you started with a turbo...
  • Replies 745
In the conversation about turboing a non-turbo... well it is my opinion that it works very well in alot of cases... If you run too much boost in any car you will destroy it... however in most cases with non turbos a bit of smart tuning and sensible boost levels will result in excellent performance for the price...
As a mechanic (sportif) I thought you would realise that a turbo car relys on enthripy... if it is efficient with good tuning a turbo motor will last for years... Come and have a ride and look at mine... I promise you it works... to the tune of a 13 second pass... no problems... it has been together for 8mths now and other than breaking a waterpump it has been perfect...
as josh says go and talk to russell mason and ask him what exactly he has done to the internals of his Petrol Nissan Patrol... it is a non turbo motor making 300 rwhp... and it has now been doing that for 3 years... no dramas...
I really enjoy the challange of doing something that "guru's" say that you can't do... and this is one thing that us Spankers have mastered... turboing non-turbos is a speciality that we like...
again come talk to us... we've actually done it... not just said that "it doesn't work"...
but what would I know... I'm not a mechanic...
Hey all........ i bet you will all see my post and think... "oh sh*t... he found us..LOL...... coz really. thats what i am..... i just tag along............ i cant belive i read 9 pages of all of that.. its mostly about stoopid muppets.. and gonza is the best.. coz me and him share a big nose gene. LOL..... so yer........ i better start thinkion about gettiing a job to start saving for a car..learners this time next year..... but im sure if i still know all of you... i should be able to get something cheaper???????!!!!!!!!!LOL
Bye all
It was me, I believe, and it was in reference to someone who had no idea about how to service their own car and who they should get to do it. Not in regards to doing certain things that void factory warranty.
Now... let's stop the "He said, she said", please.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
