  • Replies 164
My brother might be keen on doing the banner if he has some time.
He is currently helping me with recustoms website;
Sorry about the watermark but cannot have others stealing the hard work :D
Following on, if any of the executives have a good picture of a skyline, he will be able to vectorize it so it can be stretched to any size (esp a large banner)
Also, the SAU logo cant really do good if its a jpg..
Does anyone have a proper vector SAU logo?
Cheersu
Patrick
Cheersu
Patrick
this is the way to go guys, vector image will give much less headaches... stay away from imagery unless you have a 100mb+ version... unfortunately its a lot of hard work with the pen tool;)
This is why these competitions don't get great results, nobody (professionals) want to spend hours on something their not sure is going to be used when they could be doing the same thing and getting paid... and no offence to the other guys that have had a go but something this big has major technical considerations...
That said Rekin has put quite a few hours in his illustration and I think its on the money... throw some type on there and she's done IMHO
didn't you realise i was smokin' as i was designing it?..... j/k
[EDIT]
Hey DogKnight you going to the kabab thingi tonight?
Not looking good unfortunately. But ill try my best, The guys there will all be friendly
Agreed.
I feel that i'm being discriminated against, because you don't like high MB files for a banners :blink::huh:
http://www.skylinesaustralia.com/forums/ip...ubanner2aw5.gif
Haha, I love it, thats awesome
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
