sadly no. it was badly abused years ago and shut down the whole forum briefly. so I don't think it will be coming back for users any time soon.
Oh that's a shame :P
What if it's members you know and love and trust??? :D
Yeah what Doof said...
It would help me loads, as being on the commitee with organising events I have to send lots of Pm's to keep people informed of what's going on...
Even if it was just the CC feature that would help immensly to "some" of us members
use the search button.. or even scroll half way down the page.
http://www.skylinesaustralia.com/forums/Se...ms-t205366.html
I did actually and nothing came up..so I started a thread..
I only search in this section also
The facility is there.
But for a 'one off' not really.
If you were say, a club secretary, then yes it could be turned on for that specific user ONLY... but thats about the only option
I am Vice President does that surfice?
I'm Doof...
I await my mass PMing abilites...
PS: There's only 3 of us that need it... CARN!
Wrong
whats wrong steve?
someone who can understand forum security (funky? merli?) can we turn this on for club execs in all states?
First post from my blackberry, shouldve been longer - sorry about that
What i meant to say is that execs only should have the ability - not normal users
Leave the NSW committee debate out - no relevance :)
If C is happy to enable this for Exec then as Mark said, wont be hard.
Again though, his forum - his security as it opens up the door a bit with 20-25+ users getting access to a restricted function
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
