  • Replies 58
how much for the front left stub axel?
$80 for FL stub axel, i'll give ya the whole hub assembly
How much for the drivers side window switch surround?
Still have the switch surround but it's scratched and has a small crack in it, PM if interested
have you got floor mats?...or air freshners? ...how about passenger side seat? any aftermarket goodies?
No floormats sorry, didn't come with them :( Have the passenger side seat but looking to sell them as a pair at the moment. Only aftermarket part is the front pair of Tein HA coilovers. pics coming soon
dibs on instrument cluster!!
dibs dibs dibs
PM sent
dash gear surround w/ leather boot and cig lighter - $50 ill take this just pm with price to send to gold coast thanks
PM replied
Dibbs on dash surrounds! u have PM :)
pm replied
im guessing the front bar is smashed?
pm me if available in good nick :)
Yep it's smashed up on the left side, Could probably fix it if you were inclined heh
I'll take the instrument cluster if other sales fall through :)
Looks like it's sold but i'll let ya know
interested in the cluster if still up 4 sale...
how much for postage to liverpool area?
I am keen on the rear brake calipers...
Pm sent
Cheers
https://www.sau.com.au/forums/topic/211354-sold/#findComment-3738802
I need the B Pillar covers, Drivers side Interior Triangle and the black plastic interior bolt covers (for seats and belt, from memory they are 17mm).
PM sent!
intrested in the steering wheel. post to melb ok ??
Yep, don't mind posting it. Pm sent
https://www.sau.com.au/forums/topic/211354-sold/#findComment-3740139
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
