post-1887-1225534184_thumb.jpgpost-1887-1225534196_thumb.jpgpost-1887-1225534461_thumb.jpgpost-1887-1225534224_thumb.jpgpost-1887-1225534239_thumb.jpgpost-1887-1225534320_thumb.jpg
I think mine is pretty neat - but then I would, wouldn't I?!! 2001 V Spec II, Do Luck sideskirts, Do Luck carbon rear wing stays, Nismo rear quarter pods (to add balance to the profile), 19" Enkei RPF01, carbon rear wing blade, few bolt on bits in the engine bay, Nismo instrument cluster. I still find it hard to believe that I am driving such a beautiful car!
More pics in my gallery. :)
Cheers. :)
Edited by MLCrisis
  • Replies 210
Heres Mine , not finished yet but looking good !!! let me know what you guys think..Got a Z Tune Kit,LMGT4 Nismo Wheels ,
Soon to come Z Tune bonnet , Ganador Mirrors, and some other little bits and pieces .. Will take proper photos once its done !!!
ur a P PLATER>????
you cruel cruel bastard!
wish i could ride in an R34 GTR for my P's
Yeah man! Godzilla All The Way :P:laugh:
You got real lucky in making a profit on the R32. Well Done! And its good to see an all original R32 GTR.
LOL! The car in my pic is actualy not mine, but similar.
Send you a pic sometime. Cool!
You guys certainly planted a seed with me about those pods!!!! Now i want them! here is another pic of my car.....
Did it get crashed? :)
Can't remeber the exact details, a kid took it out with a car load of his friends, hit a bump and was lunched in the air and crushed on impacted as it hit the ground, can't remember if it split in half tho..?
So yeah, it was faked!
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
