Hey guys noticed the car playing up today.. anyhows it was idling like crap and had bout a litre of oil left (i filled it less than a month ago) Pulled apart all the cooler and intake piping and it is coated with oil...also when changing gears the car will spew white smoke out the back especially between 3 and 4th and also if I give it a rev while idling.. Sounds like seals on the turbo to me.. any other possibilities?? and if its seals whats a rebuild worth??
Sounds likely to be the turbo leaking oil. Check the oil breather lines on top of the rocker covers (or your catch can if you have one) to see if they're covered in oil too.
I reckon a turbo reco wouldn't be that expensive if you remove and replace it yourself before taking it to a workshop. Try maybe GCG for rebuild kits.
Your car spits white smoke? Odd, if the turbo isn't working properly (is it noisy?) i reckon you'd be getting black smoke as the ECU would send extra fuel trying to save the engine from misfiring. That happened to my mate's S15 when his intercooler piping had a massice hole- hardly any charge.
Have you pulled everything away from the turbo (piping etc.) to see what condition it's in?
Edited by R338OY
Don't rule out the engine being rooted. Do a compression test if you're stumped. Motor might have had it. Con rod bearings could be rooted. Piston rings could be too. I guess you'd know if your engine is dying :)
The work Hiace goes through 4 ltrs of oil in a couple weeks. Engine is on it's way out (400,000kms) and it has crappy compression and munches oil up.
I'm sick of changing the oil! Did it today again :cheers:
taking off the breather hoses and everything all the cooler pipes have been removed and the air intake piping.. amongst all the piping is enough oil to cover my fingers not just a lil but a thick black film
That can actually be normal. I don't have a catch can and when i ram my hand into the intake pipe, just where the breather hose goes into it, i come out with a layer all over my fingers.
Is it HEAPS of oil, or just a film?
i wouldnt think the engine is gone...but hey you never know..ive just pulkled off stuff like the bov and even the piping from the turbo and it is all covered in oil.. does anyone know what the numbers should be on the stock turbo..thgis doesnt look stock
sorry this is the r33 whoopps :) yeah think its def turbo pulling it off now and there is a lot of oil in the mouth of it..
other spots I found plenty of oil and I mean enough to leave a pool are bov piping, cooler piping, throttle body and piping and they piping from the turbo.. I did find a split hose on the rocker cover and have replaced this now as I just happened to have a spare in the same size..
also just thought id say I checked the turbo no real shaft play of anything so thats good :) at lkeast if worse comes to worst ill know its just oil seals..i've cleaned the pipes filled it with oil and put new plugs in it Ill drive it for the next few days and see how it goes..
is it worth while giving it a hard time or will everyday driving do the job?
I still believe you are yet to find the issue :)
If the motor has been damaged, you'll be getting a lot of blow-by and if all your plumbing is std that will all go into your intake, through the turbo and into the ic piping, etc.
When i cracked a piston ring land, the car sounded normal to my ears, ran and came on power normally. But as soon as my mechanic heard it idle up his driveway he knew straight away. My only indications were a small puddle of oil under the pod filter, after a track session, and it was harder to start in the mornings.
On the other hand it can be turbo seals.
So do a compression test and that would confirm the fault. If all 6 cylinders have similar figures, than your turbo seals are stuffed, if one cylinder is really lower (20+psi) than the others then its engine rebuild time.
hey guys my turbo i think, makes a noise like this RRREEEEEEEEEE lol, under load, hi revs..
i think its standard 32 but i could be wrong, still ceramic an all..
um and 15psi gets put threw it every day..
goodnight turbo?
fan belt stretchin under load?
how long left till turbo dies?
can i screw the engine if i keep it up?
sorry to hijack...
thanks chris
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
