Paul-e Posted April 1, 2008 Share Posted April 1, 2008 Hey Guys, Was wondering if antone knew what was causing this problrm. When I turn my stereo on low volume you can hear the engine revs through the stereo. Is it the wiring? Cheers Link to comment https://www.sau.com.au/forums/topic/213050-car-sound-coming-through-sound-system/ Share on other sites More sharing options...
Trent04 Posted April 1, 2008 Share Posted April 1, 2008 not sure mate, but awesome set-up:) Link to comment https://www.sau.com.au/forums/topic/213050-car-sound-coming-through-sound-system/#findComment-3763196 Share on other sites More sharing options...
punisher6942 Posted April 1, 2008 Share Posted April 1, 2008 yeah champ its the wiring that needs checked...... its more than likely whats called an "earth whine" which just means that the earth wire needs some attention.... but it wouldnt hurt to get all the wiring checked out as i have had some pretty big systems in my time and i know how annoying an earth whine and other engine sounds can be when u want ur system to sound crystal clear...... what brand of sub and amps are u running in there champ???? if ur interested in some clarion subs and amps pm me and ill send ya some pics and details of my gear..... its all basically brand new.... i have had the system for a while but have recently replaced the subs with new items of the same model purely becuz im a perfectionist lolz or if u wanna grab my msn off my profile and we can chat there about what u should do with the wiring situation Link to comment https://www.sau.com.au/forums/topic/213050-car-sound-coming-through-sound-system/#findComment-3763222 Share on other sites More sharing options...
Paul-e Posted April 2, 2008 Author Share Posted April 2, 2008 Cheers for the comments guys, but I can't take credit for it, I bought it with the stereo in it. The amps are Blitz, 1x1000w and 1x5000 which I'm pretty sure are cheap ebay items? And the subs are Sony 15" explod 3000w in custom boxes which he didn't line with any dampers, so that's a job for this weelend. Thanks for the offer of amps etc, but will stick with what I've got for a bit. Getting married next year (yeah I know,lol) so no $'s for luxury items at the moment. That's why I bought the skyline. last chance before I don't have 100% say in where my dollars go. Thanks for the help too, will have a look over the whole wiring and see what I can find. Skyline on!!!! Link to comment https://www.sau.com.au/forums/topic/213050-car-sound-coming-through-sound-system/#findComment-3764358 Share on other sites More sharing options...
Vik Posted April 2, 2008 Share Posted April 2, 2008 Dude, have u tried to put in an inline filter which cancels the engine noise coming through your speakers? Goto jaycar or an audio specialist and they will provide you with a filter. Fixed all my mates problems when i got him the filter. Aint that hard to install aswell. MR_XTC Link to comment https://www.sau.com.au/forums/topic/213050-car-sound-coming-through-sound-system/#findComment-3764771 Share on other sites More sharing options...
DazWah Posted April 2, 2008 Share Posted April 2, 2008 filter only masks the problem, most likely too small negative wire or its not good enough contact with the chassis. Link to comment https://www.sau.com.au/forums/topic/213050-car-sound-coming-through-sound-system/#findComment-3765101 Share on other sites More sharing options...
Paul-e Posted April 2, 2008 Author Share Posted April 2, 2008 Howdy, cool, it already has a filter on it. So will check all the connections etc on the weekend. Hopefuuly that will fix it. Am just turning it up loud till then so I can't hear it,lol... Cheers Link to comment https://www.sau.com.au/forums/topic/213050-car-sound-coming-through-sound-system/#findComment-3765989 Share on other sites More sharing options...
some_cs_student Posted April 3, 2008 Share Posted April 3, 2008 Is this different to alternator whine? I found this but I don't know who wrote it, someone on the internet: "As mentioned earlier, I found a harness that runs in that bay-area, and behind the AC unit that has MASSIVE electrical interference. I could hold the rca's near it, and the whine was louder than the music (at mid-levels). If you can't test it that way, then grab a 3.5mm stereo mini jack (same as your earphones) to RCA boot, and use the ipod plugged into them, so you're nowhere near the body. If that is still noisy, change your RCA cable... use a short one to test with the ipod to the amp. Grab one out of your TV/DVD player and test with it. If the noise is still there, try and borrow a friends amp, and retest all of the above. Turn your gains down on the amp. Put a massive earth on the battery. OR use a Ground Loop Isolator from autobarn etc. " This article also talks about alternator whine: http://www.skylinesaustralia.com/forums/Ca...dio-t94069.html But your problem may be different.... EDIT: re-read your problem, it doesn't sound like alternator whine....but I don't know that much about car audio. Link to comment https://www.sau.com.au/forums/topic/213050-car-sound-coming-through-sound-system/#findComment-3768069 Share on other sites More sharing options...
schnorky Posted April 3, 2008 Share Posted April 3, 2008 dude u need to ground the muthaf*#ka up i had it b4 and made me crazy the filter works a little bit but makes the quality shit (reduces bass) bcoz u runing sum high power gear i sugest u double ground your equipment, even add anotha ground coming from the batterie should fix the problem Link to comment https://www.sau.com.au/forums/topic/213050-car-sound-coming-through-sound-system/#findComment-3768386 Share on other sites More sharing options...
Chris Rogers Posted April 3, 2008 Share Posted April 3, 2008 ^^ english my friend - speak it? go to your local audio store grab a ground loop isolator. it is a patch for the problem but in you case will be easy to implement. Link to comment https://www.sau.com.au/forums/topic/213050-car-sound-coming-through-sound-system/#findComment-3768880 Share on other sites More sharing options...
Paul-e Posted April 4, 2008 Author Share Posted April 4, 2008 Cheers, will do. ^^ english my friend - speak it?go to your local audio store grab a ground loop isolator. it is a patch for the problem but in you case will be easy to implement. Link to comment https://www.sau.com.au/forums/topic/213050-car-sound-coming-through-sound-system/#findComment-3769416 Share on other sites More sharing options...
caelum Posted April 16, 2008 Share Posted April 16, 2008 Is your power cable running up the same side as any of your RCA's? Having RCA's too close to power cable will cause this noise.. Link to comment https://www.sau.com.au/forums/topic/213050-car-sound-coming-through-sound-system/#findComment-3799695 Share on other sites More sharing options...
D3RV Posted April 16, 2008 Share Posted April 16, 2008 Is your power cable running up the same side as any of your RCA's? Having RCA's too close to power cable will cause this noise.. That's most likely the problem. Exactly what happened to me But the RCA's going down one side of the car, and the power cable to the amp on the other. Link to comment https://www.sau.com.au/forums/topic/213050-car-sound-coming-through-sound-system/#findComment-3800635 Share on other sites More sharing options...
Paul-e Posted April 16, 2008 Author Share Posted April 16, 2008 Howdy, I think they are, the guy who I bought it off put in the stereo and I don't think he was all there. Unfortunately I've been flat out with work for the last 2 weeks and haven't had a chance to dig too deep into this problem. I'm going to try and get onto it this weekend. Thanks for all the help, it's been invaluable. This site rocks! Cheers to all! Link to comment https://www.sau.com.au/forums/topic/213050-car-sound-coming-through-sound-system/#findComment-3801269 Share on other sites More sharing options...
Jmaac Posted April 17, 2008 Share Posted April 17, 2008 You just need shielded RCA leads high tension leads generally cause the interferance Link to comment https://www.sau.com.au/forums/topic/213050-car-sound-coming-through-sound-system/#findComment-3802083 Share on other sites More sharing options...
Paul-e Posted April 17, 2008 Author Share Posted April 17, 2008 Sweet as! I know the ones from the amp to the subs are shielded, but will check the ones from the head unit to the splits. Awesome thanks for that. (: Link to comment https://www.sau.com.au/forums/topic/213050-car-sound-coming-through-sound-system/#findComment-3802195 Share on other sites More sharing options...
floydiangreen Posted April 17, 2008 Share Posted April 17, 2008 hi, i had the same problem in my pulsar, i added all the off the shelf filters and stuff and it still was there, i tracked it down eventually to poor rca leads, which was the last thing i thought it could be but it turned out that the rca leads that came with the wiring kit were not properly shielded, that is the shield did nothing, it is supposed to connect from one device to another, i went out and bought a high quality set of rca leads and that ultimately fixed the problem. BEWARE OF DODGY RCA LEADS, EVEN IF THEY LOOK COOL. The best investment any car enthusiest can make is a good quality multimeter, like from altronix or jaycar, mine cost me 10 bucks but potentially saved me hundreds by not having to take the car to a auto elec. another thing you can try is getting a ferrite core from dick smith or jaycar etc and completing as many turns as possible of the speaker wire around it, this will eliminate most RF interference byĀ notĀ passingĀ itĀ intoĀ theĀ speakerĀ cableĀ butĀ allowingĀ audioĀ frequenciesĀ toĀ pass. dave. Link to comment https://www.sau.com.au/forums/topic/213050-car-sound-coming-through-sound-system/#findComment-3802765 Share on other sites More sharing options...
Paul-e Posted April 18, 2008 Author Share Posted April 18, 2008 Once again, cheers to all for all the advice, I've written out a shopping list for the weekend and will hopefully get time to have a play tomorrow. Much appreciated again. Cheers, Link to comment https://www.sau.com.au/forums/topic/213050-car-sound-coming-through-sound-system/#findComment-3804134 Share on other sites More sharing options...
Jet_33 Posted April 25, 2008 Share Posted April 25, 2008 When teh car is on ACC you dont here it but wen teh engine is on it starts to happen am I right? I think you might have to connect RCA wires from the headunit to the amp. Similar problem I had but mine sounded like the turbo coming from my speakers? Link to comment https://www.sau.com.au/forums/topic/213050-car-sound-coming-through-sound-system/#findComment-3822045 Share on other sites More sharing options...
turbo_brian Posted April 27, 2008 Share Posted April 27, 2008 I have a similar problem, but mine's caused by the grounding from the battery to the Chassis to the engine block. I ran 4 guage power from the battery to the amps in the boot, ran speaker wires down the other side of the car, did all the rules, but got the noise. When I placed another 4 guage wire on the negative of the battery, and to the chassis, the noise vanished straight away, so something to check before ripping all your stereo gear out is the basics, lift the bonnet, have a look at the negative wire, especially in the R32's, as mine's only slightly bigger than an 8 guage earth, completely inefficient for anything more than a stock headunit. B. Link to comment https://www.sau.com.au/forums/topic/213050-car-sound-coming-through-sound-system/#findComment-3825543 Share on other sites More sharing options...
