i had my car locked the other day but with the windows down (force of habit to lock the car) and realised that i had forgoten something so i reached in and unlocked the door grabbed my stuff and all of a sudden the horn started blarring at me. scared the bejesus out of me. has anybody come across this before in one of there cars. the importer that i got the car of didnt even realise it had an alarm. i have found a little switch on the d/s kick panel that turns of the flashing led on the dash but i havent gotten around to testing if it has anything to do with the actual alarm.
https://www.sau.com.au/forums/topic/213332-factory-upgraded-alarm/
Has anyone else got the 'NISSAN SECURITY' arial/reciever unit that sits in front of the rear view mirror. I have and i dont know what its purpose it?
Not sure if this is related or not (dont want to hijack your thread)
Hmm yes I do, I thought it was a GPS antenna for my xanavi unit? Either that or something for the Toyota Electronic Toll Controller unit that's been installed...
This little jigger is the antenna for the remote starter. It flashes when the alarm is armed. If you don't have the factory remote or the compliancer fitted an immobiliser it is practically useless except for looking pretty.
Dave, the Factory GPS antenna sits under the dash just in front of the clock. If you had the ETC toll collector unit, you would know as it is pretty obvious.
See here: http://www.skylinesaustralia.com/forums/Da...=remote+starter for more info on remote starter/alarms
Is it true that the Mongoose M80G will function in this way ie. off the Nissan key remote?
Not in my case - I've got the Nissan factory remote key, but I leave it at home and just use the copy I had cut, as it saves me from carrying around the bulky key AND the remote for the alarm.
I think the issue is that the Mongoose uses a rolling code remote, but the factory key doesn't.
Thanks :devil: Yeah I have the ETC toll collector unit, it's a big box taped to the side of the centre console, and when you push buttons on it it says things to you in a female Japanese voice...
Thanks :thumbsup: Yeah I have the ETC toll collector unit, it's a big box taped to the side of the centre console, and when you push buttons on it it says things to you in a female Japanese voice...
uh huh "Insert your ETC card please". Pretty easy to remove. they normally patch it into your cig lighter power.
ahh I wondered what it was she was saying lol
Not patched to ciggie lighter for me though, was a whole massive loom in there with about 10 metres of cable, cable tied up, with 3 wires, one of which was earth, and a whole custom short loom with a false plastic plug in the end that went nowhere... I'll try to get a pic of it all its crazy
Edited by DaveB
  • 10 months later...
sorry to bring up an old tread but i just bought a S2 stagea and its got the thing infront of the mirror and its got a retro looking remote thing as well.. i'll post a pic when i get home.. its got start/stop - check and alarm set on the unit. can't get it too start though, the dash lights come on but go off straight away.
yeah got the same things, cept mine is on what looks like mini mobile phone.
have you got a turbo timer installed ?
cause once i had my tubo timer installed, i can no longer use the remote start. but now if i push check it would tell me that the engine is off, temp inside the car and if its locked or not.
now with the turbo timer installed i push CHECK it will tell me that but the mirror's will fold out , the stereo will come on and the lights on the dash will come on also, then the turbo timer will switch on for 30seconds and everything will shut down.
so basically my factory alarm key from nissan is useless as it only locks and activates the alarm. and some times it doesnt de-activate and im left in a very messed up situation at shopping centers !! so its in no use anymore, just using the key with lock/unlock on it now.
hope that helps to your question :S
here are some photos of the remote unit and the reciever.. i played around with the remote and i can't get it to do much at all.. it beeps and the lights come on but thats about it. when you press the start button it beeps then the dash lights come on for about 1 sec then go off again. p.s i don't have a turbo timer installed
wow that looks different.
mine is the same setup with the buttons but i have a lcd screen on mine . . . . i once started my car from about 250meters away. i was on a hill though in my truck on a cold day. thought what the hell, got to my car engine was warm, had the heat on in the morning so it came on also, aswell as my seat warmers, bloody good idea. only thing is, when i open the door it shuts down. . . like a theft thing i guess
i have that remote and the thing behind the rear view mirror. but mine does nothing, i think during compliance the power was cut to it. there are some weird boxes under the steering wheel and some funny wiring thats been cut off
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
