  • Replies 110
Great work with your build. Its refreshing to see someone sharing their assembly process with such detail.
Now when someone has RB26/30 buld questions they can just come to your thread instead of being flamed for not using the search button (which produces more BS than real useful information).
Do you have a purpose in mind for the car? Drag, street, track or all of the above?
Hi, just wondering if you have felt the clutch yet, im looking at having to remove the clutch booster to fit my plenum. Also why did you go for the integra master cylinder instead of the original one?Was it due to the fact the stocker doesn't have provision for a fork?
the clutch feels fine..i don't feel a different without the booster
thanks ....
i will keep the updates going ..when i am back in canada..
i am currently traveling around tokyo and HK !
  • 3 weeks later...
more updates !
it's finally looking lik a car now!
with fuel system completed !!!
starting from the back
fuel lines protector guard !
fuel line holder
at the front
dash completed ! glued the back together !
heat sheild for turbo and down pipe
hand made wrap!
HKS to4Z turbo bell mouth machined to fit with my T78 greddy turbo
since the engine is 3inches taller...we made this angle down so i can use my billion rad hose instead of getting soemthing else
polished PS tank
so more work done @ Keep Performance Lab today ~
i must say these guys are so Good with Wires !!!
again keeping it clean is always on the top of the minds. so organizing the wires were very important as it is easier to work on as well as it looks alot nicer.
here are some pictures from today
back of the kill switch mounted where the rear wiper used to be
attention to details
Keep Performance lab even got the Bolts on a OLD HKS coilover GOLD PLATED
my external oil pickup as well as both the external head oil drain and turbo oil drain (had to reuse some old fittings as i don't have time to get new one anodize gold)
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
