Hey,
Seeing as GTT34's PM box is full, does anyone have any good pictures of his car?
Im after a 45degree front-side view of his car displaying his recustoms shtickers.
Or Rays (recustoms) s15 in a similar angle.
For example; but more brighter/clearer photo. also more from top-down view.
Thanks
- Patrick
https://www.sau.com.au/forums/topic/213535-need-pics-of-gtt34s-car/
there's a pretty good shot on the "members rides" section on sauvic.com.au ...
ah yes, very close to the picture im after :devil:
As Dezz mentioned, planning to use it in the recustoms website, so the shtickers are needed :(
Thanks all for the pics, keep them coming.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
