hey everyone, not sure if this is the right section to post in or not.. but here goes
i currently have an R32 gtr, and i want to swap in the engine, getrag 6spd tranny, rear diff, ect into my r32 gtr, i will be getting a complete R34 front cut with tranny/ complete rear subframe etc
now, i know the attesa in the R32 is hydraulic, and the R34's are electronic.. so how would i go about this? will everything be pretty much straight bolt on?
anyone else done this before?
anything else i need to know about other than the attesa?
any help/info/points in the right direction are greatly appreciated!
Edited by derk
https://www.sau.com.au/forums/topic/213649-r34-gtr-powertrain-into-r32-gtr/
Gearbox goes straight in
But you will need
34 gearbox with mount
34 gtr clutch,
modify the shaft, ( i think its joining the 34 front half to the rear half of the 32's tail shaft... i cant remember what we did with mine)
clutch slave obviously
and all attessa is hydraulic.. on the gearbox side of things anyway..
no need to change diff.
Edited by Angus Smart
If you fit the r34 engine, then you need to fit the r34 diff, as it has a vastly different ratio(4.11 vs 3.5 i think)
do you mean gearbox instead of engine?
i do agree with doing the swap, the 34 box is nice and streetable, and also has very short ratios which i dont have a problem with.
i was lucky and scored a nismo imput shaft with mine, which is almost twice as thick as standard
i'm still running the 32 ratios i believe. tho may have been changed before.
im just looking to build a 500hp ish gtr street car, i like the getrag 6spd, and the helical lsd that the r34's come wtih, and i have connections that can get me an r34 front cut for cheap, so i might aswell haha.
that way i dont have to fix the R32 oil pump drive on the crank.
the motor will be stripped and built from the ground up, so really i guess im just after hte getrag and the hlsd haha, everything else can be done with the r32 motor i guess.
yes i think thats what i mixed it up with, the hicas, ill be ditching the hicas while im at it.
well front ratio is in the sump, so unless he changes the sump he gets the r34 diff.
Shit, i forgotten about the diff in the sump, i'll be installing a 34 engine soon. what would be best to put in? or just use my diff from the current 32?
I think the getrag would be perfect if your not paying much! I paid alot when i done mine but i'm not complaining, i love it for the street the ratios are quick and it can take a bit of abuse..
i've also got a 34n1 motor on its way so we're doing pretty similar things.
if you want a carbon shaft for 1400 be sure to check it the group buy. need a few more people
you'd be better at just doin the gearbox and diff swaps if you really want the getrag and diff ratios.. as for the r32 oil pump drive on the crank issue.. just buy a new r33 gtr crank.. there only 1000bux for a brand new crank.. much cheaper than buying r34 front cut and goin thru all that conversion shit...
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
