  • 10 months later...
  • Replies 53
Hey guys,
I feel like an idiot, but I have to ask cause I can't find anything about it.... :P
Car: R33 GTS-T Series 1
Will a JJR 3" Bellmouth front/dump pipe fit to a stock cat without any mods?
Cheers, :D
Chris.
Hey guys,
Cheers, :D
Chris.
i am assuming yes, my 3" catback bolted to mey stock cat... but IMO, do the JJR catco 3inch cat with it! My car runs cleaner, and breathes heaps better, funnily enough, when i did the dump/front/cat it sorta "cleaned up" the exhaust note!
  • 1 month later...
ive got a trust pe2 titanium exhaust just from cat back...and honestly nice performance growl (very unique titanium tone) and on high revs sounds like a well modified car...
getting a 3 inch metallic highflow and fujistibuto down pipe when i install my hks 2835 pro s kit with hks dump 3"...should so sound a treat...ill let you know how it sounds.
Hey Guys, I was wondering if anyone knows if a R32 dump pipe and front pipe would fit a S2 RSFOUR? I know the dump pipe will, im just not sure about the front pipe. If not i guess i'll just get it modified to suit as its just sitting in my shed from my old RB20.
Edited by DSTROY
chad, id say if the front pipe does, then the dump will... i couldnt see y not. only thing is getting the dump off on mine was impossable... bit of a hard position and bolts wouldnt budge... kidafa has a stock dump you could line it up to.. if not $205 delivered from just jap. to be 100% honest i noticed no difference with a dump pipe on my s2... ill get chomped for that but yeah. plus looking for the pipe the bolt in the 3 oclock position is very hard to get in!
We'll have to meet up after i pick up the Stag so we can have a look at the 2 pipes side by side. The dump pipe should make a difference, i noticed it on my RB20 years ago.
Here's a pic of the pipes.
Hey ,i went custom on mine, place on blackburn road "waverley exhausts" ,3" mild piping, with a high flow resonator,cat and muffler in stainless
its not too loud but has a good note when i put my foot down
They were really rude to me so i went to rowville exhaust centre, did a great job.
So I'm looking into replacing the stock exhaust on my M35 ARX.
It it worth going the whole way with a turbo-back, or should I save the $$ ($$?) and just get a cat-back? I know there are some serious performance gains to be had by doing the whole thing, but how much more is a dump + cat likely to cost? I'm unlikely to upgrade the turbo etc in the future (even if it fails) so I'm not going to need massive flow down the track.
With the aussie dollar the way it is I'm assuming I'll be better off getting something made locally rather than importing something?
Also, I'm in Adelaide - does anyone have anything good/bad to say about any exhaust workshops? I have emailed 3 well-known shops today for some quotes, but if there is anyone else around that has worked on M35s it could make the process a bit easier.
I have been reading comments by MXFLY who fitted a dump pipe and high flow cat and kept the standard exhaust whilst waiting for a Legalis exhaust to come from OS.
He commented on the turbo spooling faster and pulling harder than stock.
Have a read of this thread, http://www.skylinesaustralia.com/forums/Nm...mp;hl=dump+pipe.
Cheers
Andy
Actually, speaking of Fujitsubo...
Who can get the Legalis-R for the C34 around here?
Nengun only have the NM35 listed, as do RHDJapan. I see plenty on Importmonster, but no direct Aust. suppliers and the cost is just prohibitive.
I'll probably end up heading the same way as you Ryan (as we've discussed), but would be interested to see what kind of price the Fuji can be had for.
Any good performance shop that brings in import parts should be able to get a Fujitsubo Legalis R system for a C34 Stagea. I got mine about 18 months ago from a place here in Melbourne called Revzone. I got the Legalis R Catback and Front pipe all in 3 inch, it cost me $1600 fitted. Best purchase I have made for my Stag sounds great and goes hard and looks like a standard exhaust so no issues with police.
Here is a link to the exhaust I have http://www.fujitsubo.co.jp/product01.php?n...000000000002783
Whatever you do, make sure you get at least a dump back.
Cat back won't help you much, but will have a nice note (usually).
You can get the Liverpool Exhaust dump+cat combo in NRVOUS's thread delivered to your door for about $850.
Then you can either get a custom cat-back or a JDM cat back.
The JDM unit will usually set you back a bit more but it will bolt straight up, have a very nice flow rate and sound great!
If you can stretch for it, go with the Fujitsubo Legalis R, great flow, FANTASTIC sound and is pretty quiet when cruising.
hmm dump/front + cat for $850 delivered ay???? Oh. So. Tempting.
+1 for fuji exhausts
That is delivered to Melbourne. You could just drive to Liverpool & get it installed.
Would be even cheaper.
I think that if I was getting a custom dump made up, I would change the turbo to something larger...
hmmm... Anyone wanna buy an M35 HiFlow? lol...
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
