  • Replies 53
hmm dump/front + cat for $850 delivered ay???? Oh. So. Tempting.
+1 for fuji exhausts
mmm. Maybe it is time to see if we can get a discount for a group buy?
anyone else interested.
PS. Ian will fit it for you. LOL
Great idea, K Rudd's giving me some money soon, spend it on something Aussie, keep the money here!
They will. :D
The price I gave earlier was inclusive of shipping to Melbourne.
lol...I asked about this dump pipe 3 months ago and they told me $1,250 fitted...they have obviously changed there tune......don't mean to dis them but I have used them in the past and there now a dirty word to me.
P.S. You get what you pay for!!!!!
Interesting.
I was given that price around middle of Jan this year.
Actually, speaking of Fujitsubo...
Who can get the Legalis-R for the C34 around here?
Nengun only have the NM35 listed, as do RHDJapan. I see plenty on Importmonster, but no direct Aust. suppliers and the cost is just prohibitive.
I'll probably end up heading the same way as you Ryan (as we've discussed), but would be interested to see what kind of price the Fuji can be had for.
i was quoted 1400 when the rate was good!
try rhdjapan.com or their bidjdm site or what ever it is, they also do second hand, e-mail them on RHD, they're champs
Ryan, Xforce rear bufflers, get custome pipe done, second muffler, custome pipe, cat, front and dump.
real cheap :blush:.
give Re Customs a call
you obviously havent heard my car :D EPA legal 3" turbo back
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
