Hi guys,
First up I own a 98 R33 S2 GTS25T Skyline with the following mods:
HKS Cat back exhaust
De-cated
Pod Filter
GFB Hybrid BOV
I've noticed a oily smell incabin... partically when i'm slowing down or have just been giving it a bit of stick. I changed the oil about 4,000km's ago with Shell Helix 5w40. This problem has only seemed to arise since I've de-cated the exhaust?
Any ideas what it could be?
https://www.sau.com.au/forums/topic/214551-r33-s2-oily-smell-incabin/
Check that you haven't caused any exhaust leaks during your decating process (did you replace gaskets) Do this by letting the system cool down completely and rub 50/50 dishwashing liquid and water over the flanges. Then start the car and look for bubbles...
Yeah, I'm not sure about the gaskets - An exhaust guy fabbed it up and installed it.
I guess I'll jack my car up tonight and unbolt it and have a look.
Cheers mate, also I was looking at some Fuchs 5w40 oil, whats that like for a RB25DET?
Edited by dekodE_
FWIW there are heavy penalties for removing emissions equipment (ie decat) for a car that's used on the road. A high flow (magic cat/metal cat/catco) style cat shouldnt restrict power at all on your setup, and will reduce the smell and the amount of black crap that will end up on your rear bar.
you may also have a leaking rocker cover gasket. usually passenger side. the oil gets onto the block, and when boosting around, the higher block temps burn the oil and you can smell it quite a bit.
what the f is FWIW?
lol ...for what its worth
Edited by Munkyb0y
Fuchs is fuching good stuff! :) Pricey but worth it.
Sweet, I think its about $79 for 5L which isn't too bad. I might grab some tommorrow.
Had a look in the engine bay for any leaks, and tried to "sniff for oil" couldn't find anything.
Then I took the car out for a spin, It was only really noticeable once I had come to a stop (So i'm still thinking it's an exhaust leak as first suggested, guess I'll jack the car up tommorrow and check it out.
My current oil level hasn't changed, and my car doesn't smoke at all, even on boost... :laugh:
Edited by dekodE_
The rubber seal around base of your gear shifter might be split. That will give off an oily smell in the cabin.
exactly what i was goin to say..my car had a short shifter in it when i bought it but i didnt like it so i bought a gtr shifter to replace it..when i went to take out the short shifter i found the previous owner had put a tea towel around it to stop oil spiting out which stoped the smell getting to the cabin and the short shifter had no seal..so i had to buy a seal from nissan when i put the gtr shifter in and i removed the tea towel..i had an oily smell in my cabin for round 2 weeks but its gone now :D
Interesting idea's being thrown about when OP said...
...This problem has only seemed to arise since I've de-cated the exhaust?...
Every cat'less car i know has a particular smell to it. Hard to describe. When idling, and a breeze blows the fumes into the cabin, smells kinda oily i guess; sure its not just that?
If your sure it only started when you ripped the catback off, smashed the china out of the cat and shlaped it back on... then start there first.
LoL @ Luciano_GTST.... Google will tell you all abbreviations ;)
Edited by GeeTR
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
