Hi all,
just looking at buying a R32 GTR and having never driven one before im not too sure if this is normal or not but i was pushing it a little hard around a few roundabouts like nothing too insane just gently acclerating through and the back end seemed to be swining out quite easily. Just wanted to know if this was normal for GTR's because there is hardly anything weighing down the back?
Any feedback would be greatly appreciated and any other buying tips for the 32 GTR's.
Thanks.
https://www.sau.com.au/forums/topic/214573-r32-gtr-handling/
Hicas can kick in on average speeds and kick the rear end out which is bloody annoying and scary at the same time. Have a look under the search banner for 'hicas lock bar' and that should solve your problems.
Also, our attessa system in the 32 is a little slower to react to wheel speed etc and only calculates 10times/sec compared with 100/sec on later models. Thus, the car will experience a little more power oversteer than other GTRs
Could be a number of things - eg. if the cars been lowered and hasnt had adjusters added to the suspension arms the rear geometry will be stuffed.
Look in the General maintenance section for a buying tips thread.
Just take it easy. I see a few 1st time GTR drivers tend to over steer the car cuz they are not use to the HICAS.
Its the rear wheels turning 1 degree in the opposite direction as apposed to the front, to help with cornering. It's a bitch doing a 100km/h on a long stretch bend of freeway and the HICAS will start to kick causing the rear to pop out abit.
Its a bit hard to tell if what you are describing is normal or not, but yes the GTR is tail happy compared to a lot of other cars out there, remember it is a powerful rear drive car (mostly). It can take some getting used to depending on what you are used to driving.
I'm not convinced HICAS is the end of the world, more likely a lot of people's problems are poor alignment and worn (15-20year old) rear bushes which cause the tail to move around a little.
i agree with duncan.. ive had all my bushes replaced when i got the car and although it does have apexi N1 suspension, it handles really really well, well enough to leave my mates 06 STI and my mates evo 8 behind down the black spurs.. ive also had my computer remapped and the hicas tuned more aggresively.. so it comes on faster and "harder"
but ive heard stories on how tail happy they are, i just havent had the pleasure of experiencing that extreme tail happy state.. it usually corrects itself really quickly when exiting corners
get them to jack up the rear of the car - secure with axle stands etc. With both wheels off the ground, grab each back wheel in turn at a quarter to three and push/pull alternately - trying to steer the wheel. If you can feel ANY movement then somethings worn! most likely the bushes and the rear steering links. This will give the car more than the 1 deg rear steering that Nissan intended.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
