Good afternoon,
Well I have done a search and not totally satisfied with the info i have recieved on peoples experience with the 25-40 as alot of it is related to people running it on the RB20's or on RB25's with half the supporting mods, so thought id start my own thread about peoples experience running this turbo with all supporting mods.
My motor is being rebuilt with forgies, gtr rods etc, 720cc injectors, pump, cooler, exhaust and the rest..
Will this turbo be laggy with a decent setup?? I will be running standard cams/heads with a microtech ecu.
Ive read through threads that this turbo is a little laggy but its mainly from people who arnt running all supporting mods or using the turbo on an RB20..
Im hoping for atleast 240rwkws and decent boost coming in from 3000rpm and onwards...
Any input on ur experience with this turbo on a well setup RB25 would be excellent.
Thanks
Edited by Dean_HR31
https://www.sau.com.au/forums/topic/214831-bought-a-hks-25-40-for-my-r33/
Its the worst turbo of the ball bearing brigade.
It makes a tad more peak power 2530, but with a much poorer midrange... so lag vs gain its not worth it.
Moral - the 2530 is the choice, then say a 2835 or similar, just skip the 2540 altogether, old design
The 28-35 turbo was out of the question as i want a turbo that looks standard. Do not want to replace turbo in the case of an EPA.
And I couldnt find a second hand 25-30 for sale... Do they also look standard in size like the 25-40??
Edited by Dean_HR31
2530's are the same, its the comp wheel thats different (and too big)
GCG hi-flow is what you should have purchased, perfect turbo for 250rwkw :thumbsup:
Or even a GT-RS or one of the other good options on the market
Obviously though a GCG hi glow wont be of the same quality of a HKS turbo!??
I want something reliable as my engine is costing me alot of money...
Ive heard nothing but excelent reliability from HKS turbos...
Can i just have someone confirm that the HKS 2530, 2535 & 2540 all look the same - stock size turbo looking..?
I am planning to put the heat shield back on with this turbo....
Thanks
Edited by Dean_HR31
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
