Hey ppl,
just a quick thread to see which choice i should go 4. I own a 96 s2 r33 and i want to upgrade
the ecu but i dont wanna use a pfc, i was thinking either a greddy e-manage or a link ecu!
Any suggestions and wot are the pro's and con's!!
cheers.
https://www.sau.com.au/forums/topic/215338-ecu/
i used to be like u, not wanting a pfc. in the end they are soooo easy to install. and tuners are readily available
This is the main selling point.
Considering your in Townsville, I would assume you are limited to tuning workshops.
Vist the workshops, talk to the tuners and see what they use/recommend.
My R33 has a remapped standard ECU.
https://www.sau.com.au/forums/topic/215338-ecu/#findComment-3804302
hey guys, i put my car in for an ecu and i looked at my available options and im getting a link
g3 put in so i get it back tommorrow so ill tell you how it goes they are abit pricey but hopefully
its worth it. this is it if you guys are interested :
http://www.linkecu.com/products/engine-man...lder/linkplusg3
they are giving me before and after dyno readings so ill post them up when i get them..
https://www.sau.com.au/forums/topic/215338-ecu/#findComment-3812629
I'd be suggesting to have a look at a Nistune for pure ease of installation (once chipped you can still drive the car on a pre-loaded base map) and price wise... I have one on my RB20 and stoked with it so far, its not finished with a proper tuned yet as my tuner is playing around and learning the software so far, but extremely happy.
The R33 ECU is not able to take the Nistune daughterboard, but works with an R32 RB20 ECU and a base R33 map loaded, if that makes sense... The website says it in more detail.
https://www.sau.com.au/forums/topic/215338-ecu/#findComment-3812932
if you sydney you can go to toshi, who remaps stock R33 ECU!! no modfications needed or anything else..
Did mine a few weeks ago. 196kw at 10psi.
A lot of mid-range to top end power.
And all for 400 bucks :)
Check out my threads if you wish..
https://www.sau.com.au/forums/topic/215338-ecu/#findComment-3818476
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
