Okay so I’m starting to crunch some numbers now and I just wanted some opinions on what I was thinking. Basically I’m going to have a built rb30det with a gt35r pushing 22+psi and hopefully pump out 500+awhp.
I’m going to use a NEO head and as most of you know it only has a capacity of 50-51cc compared to the normal rb25 head of 60-64cc, obviously this will raise compression. From what I understand the stock rb30 piston has a compression height of 1.260in with a 0.040 deck height (so the piston sits roughly 1mm below the top of the bore at TDC). I would like to have a zero deck height, and I’m still unsure on what piston size to run, either std 86mm or 87mm because at the end of the day most rb30s out there would of done at least 250,000kms and a hone might not cut it.
So this is what I was thinking:
CP Pistons (8.2 CR in the normal rb25/30)
Piston Compression Height: 1.280
Deck Height: 0 (shave .020 off the block)
Piston volume: 0 (flat tops)
Head gasket thickness: 1.6mm
Head gasket bore: 88mm
Head chamber capacity: 51cc
Bore: 86mm
Stroke: 85mm
According to the calculations that will achieve 9.13: CR, and if I needed to run 87mm pistons that would bump up to 9.32:1 CR which is starting to get a bit high for my likings, but I could drop that down to 8.75 and 8.93 respectively by having a deck height of 0.020in but im not sure how much that would affect the quench.
OR
ACL Race Series Forged RB30ET
Piston Compression Height: 1.261
Deck Height: 0 (shave .040 off the block)
Piston volume: -4.5 (dished)
Bore: 86mm
Stroke: 85mm
With that combo I would be looking at 8.56:1 CR and with a 87mm bore it would have a 8.72:1 CR. I just don’t have any experience with the ACL pistons, how do they rate compared to CP?
Also I’ve noticed that most aftermarket head gaskets that I’ve seen come with a bore of 88mm, has anyone experienced trouble running a head gasket like that on a 86 or 87mm cylinder bore?
Any input would be great
:3some:
Edited by R34GTFOUR
https://www.sau.com.au/forums/topic/215701-rb30-neo-piston-selection/
Where did you get that info from?
Cheers
Gary
i've read it a few times on the forum, but its also listed in the rb30 PDF guide on here. Spoolup also mentions it on his site www.spoolimports.com that the combustion chamber in the head is smaller, and different pistons need to be used.
Im using the ACL's in a NEO 25/30 im building. Why do you want to run a 1.6mm HG? I would run a 1.0 or 1.2 and higher comp.
Mainly to be a bit more boost friendly, but i just did some quick calculations:
With the 86mm acl pistons it will run close to 8.86:1 CR with a 1.2mm hg and 9.01:1 with a 1mm hg
With the 87mm acl pistons it will run clsoe to 9.04:1 with a 1.2mm hg and 9.20:1 with a 1mm hg
So depending on the condition of the bore (i havent got a block yet) if i run a std piston the 1mm hg seems the go, and with the 87mm piston the 1.2mm hg seems the go
Whats some feedback on acl race series pistons? Anyone heard good/bad things? Anyone know of any high hp cars running them on a daily basis?
:down:
The ACL distributor here told me the ACL race pistons are made by Ross.
As we all know Ross make pretty sharp pistons so i think they look to be a good option.
didnt know that :down:
i can get acl at trade price so that looking better and better
thanks
If your in sydney, you can come and have a look at a set if you like.
nah im in perth cheers anyway, coventrys over here sell them and i can get trade throught them so it should be sweet. I looked at their website and it shows a set, but it has valve reliefs so im not sure if its the correct picture.
Whats the general opinion on running a head gasket bore of 88mm on an engine with a bore of 86-87mm? Is that going to cause a problem? 90% of the gaskets i've seen are 88mm for the rb25/26
mentioned to my workshop from the very get go that the NEO head have smaller cc. But they still went with the cp pistions for a r33 rb25. Dont know what comp ratio its going to end up with or how but i would like around 8.5. Will be whacking 2bar from a t04z.
hey mate,
it all depends on wat height they decked your block, your headgasket size etc but regardless i dont think you'll get it down to 8.5:1 CR
The lowest i can see it going it 8.7:1 and thats with no decking wat so ever, running a big 1.6mm headgasket and std size pistons (86mm)
Worst case senario, if they zero decked the block, with a 1mm hg and 87mm pistons your CR would be as high as 9.85, which i wouldnt think the engine would like 2 bar boost that much
Decking your block only increases your compression ratio as you are reducing your piston to deck volume ( if you have one ) and or making your piston sit proud of the deck, hence making your gasket volume smaller.
My NEO head ( from memory ) had 56cc comb chambers.
they also have a thicker top ring than the CP's, so they form quite a good seal...reducing blow-by.
good piston for the $$
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
