Hey guys,
Basically i have taken the task of removing turbo's from my R34 GTR by myself, currently i've removed pretty much everything apart from oil / water lines, heat shielding and a few other bits and pieces. Im starting to get a bit confused as to the order things need to come off, and how i go about it. Basically im wanting to know if anyone in the area (Brisbane) would mind lending a hand / knowledge on the process and could possibly help me out one day / evening. I would pay handsomely in alcoholic beverages and food! or happy to give a bit of cash depending on how much work is done! If anyone is available let me know, would be greatly appreciated! Here is a pic of the current state.
Also, have taken stacks of pics of whats happened along the way, hoping to develop some kind of D.I.Y RB26DETT Turbo removal guide at some stage ;)
Any advice / help appreciated! Even if someone could just give me advice on the order to remove the components
Edited by Got Boost?
https://www.sau.com.au/forums/topic/216074-help-request-turbo-removal-rb26dett/
From memory:
- Undo your power steering reservoir and move it out of the way, just gives a bit more room to move.
- Remove the hard lines above the heat shields (have something ready to catch the water).
- Remove your front pipe if you haven't already.
- Heat shields off.
- Oil/water lines off.
- Intake off the front of the turbos off (extra long extension bar highly useful for the rear turbo).
- Undo the nuts between the turbo flange and manifold but don't completely remove them.
- Undo the top 6 manifold bolts.
- Drop the turbos down as far as you can without undoing the bolts and with a long extension put it in between the turbo flange and manifold to undo the bottom 6 manifold bolts.
- Completely remove turbo flange/manifold bolts now and lift out manifolds.
- Undo O2 sensors and lift out turbos.
Sounds easy when you say it like that ;)
Like I said, this is from memory only so I may have missed something.
From memory:
- Heat shields off.
Thanks! Ill look over what you said and give it a go! You wouldnt know which water line is the best to drain from? I've already dumped the oil out so thats not a problem. Havnt removed the front pipes so i should do that i suppose.
I think I used the big centre bolt but I don't think it really matters.
done this job engine in more times than i care to remember....it gets easier the more you do it...just remember, when it gets to you walk away and come back after a beer/coffee/smoke etc. you will get there and feel great when its finally done.
  • Like 1
thats the way.. just make sure you start with at least a new carton of your prefered drink and new pack of smokes(if you smoke while working make that 2 packets)
  • 1 month later...
On this note, what is the easiest way of reinstalling turbos?
Considering how much of a bitch it was to remove the rear manifold underside nuts, it must be easier to lift the rear turbo into position from underneath. Trialled the new one all rigged up through the hole and it 'should' be a possibility.
Any other helpful hints would be appreciated.
From memory.... it took us two cartons of beer.......
do you guys have any tips for just changing the extension and dump pipes?
How much beer do I need lol?
alot.. tis flamin mongrel of a job.. small hands.. perhaps the small hands of an eager to learn young teenager.. something that can bend into like.. a snakey S shape.. prolly only carton of piss for changing dumps.. front pipes are easy to change but dumps are ghey.
:D
Gotta agree... A bitch of a job... Find someone with small hands
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
