Yep, as you know the GTR cams weren't designed to work like this anyways.
Funny you should ask that. I have test driven a dead stock r33 GTST manual and the power delivery is pretty much the same except for the mad throttle response on this.
I'm curious to see what he gets down the quarter. Low 14's maybe. Old RB30E was a best of 15.6.
I'll post up the dyno graph next chance I get.
  • Replies 61
That's a good baseline for a NA to be run in. Especially considering the cams aren't matched, the gearbox sounds dodgey, probably needs a better diff most likely, and didn't you say it needs everything from the extractors back looked at? That's pretty impressive really. Run in properly with a (much) more aggressive tune, and those problems sorted out it will be interesting to see its actual power output.
I am left wondering how much torque it is currently producing.
While I'll never have enough cash to do it myself its an awesome project. Keep us posted with the details!
Well I finally got around to becoming a member of SAU, I'm part of the R31 Skyline Club.
This just happens to be my car, I think someone wanted the dyno graph:
The red line is the new motor RB30DE (186 rwhp) and the green line is the old RB30E (134rwhp).
Hoping that the diff and gearbox hold together down the track it should be good for approxish 14.3 secs, just about the equivalent of a turbo 1J in a soarer, with very mild modifications.
nice work. if it were mine I would be getting rid of the factory plenum and get some individual velocity stacks. the stock intake is designed to work under pressure and my bet is it's holding you back as it's not suited. even consider some larger throttles, Garage Saurus make a few different options for 26 head that still wants the 6 throttles, just bigger. definately get the intake and exhaust ported and get some big cams in there. around 280-290 degree and 11mm lift+, you'll need the valve springs and retainers to suit and some clearancing work in the head but you've come this far and these finishing touches will really make it nice. the thing is though, to make power with this NA engine you need revs. with the big cams and a better intake you'll be able to make the most of the top end. as long as your bottom end is strong you should be able to rev it to 8500+.
anyway, very cool idea and certainly something different in aus. enjoy. :thumbsup:
They are roughly 47-48 mm diameter standard.
Trumphets on the throttle bodies (read modified plenum), more aggressive cams etc would be a good starting point :P.
This would be nice lol. 380 hp at the crank, RB26/30DE
Edited by GTRsean
Perhaps there is gains to be made with cam timing ajustment and more tuning?
Yes there can be more adjustment made with the exhaust cam which would give it a definite power increase.
But I don't know if I should spend $500 and get cam gears or spend $1500 and get cams which would give a massive increase in power??
Oh yeah its still running the 1986 2.25" press bent exhaust, so a stainless 3" would help out a lot as well
Edited by Silhouette-R
It depends on budget of course, but cams would give the greatest bang-for-buck in a build like this. Just remember to change the valve springs etc because I doubt they were designed for a lumpy NA cam.
Its good to see someone doing something different despite all the people running around slagging it off. Good job.
Yeah the cost that I mentioned ($1500 - $2000) would cover the new cams, new springs and the machine work + tune involved putting the new cams in, but the new cams would not be till after Christmas.
I'll put the new exhaust on first so that when the cams go in there won't be anything restricting them, but I'm thinking if the head is going to be pulled off the motor I might get the rods done as well, since it will want to rev like crazy.
stock rb25 rods are nitrided from factory and i think are also shot peened and will handle 8-8500rpm for short periods
cams will shift the power band up, but even at 8-8500 i would imagine that they would be out of puff anyway
i see no need for aftermarket rods
Edited by 342Four
I want to get aftermarket rods cause i'm still running the Rb30 rods which aren't designed to rev into the 7-8000rpm range.
And I don't want a rod going through the block, not good.
yeah but you can do cams and all that with just the head off.
rods means the whole lot has to come back out, then it goes downhill from there moneywise.
-rods leads to...
-full balanced bottom end (crank, balancer, pistons, race bearings, etc.)
-then the cams and head work (port, polish, oversize valves, etc.)
i looked into the same motor setup - and me personally i'd much prefer to do the whole lot at once than gradually do one mod at a time. it's a lot of coin initially but saves hassles down the track. best way is to start with the block and leave the head stock, then when you get coined up do the head. however that's not how people usually mod cars (head first, then block).
the money is why i scrapped the idea. i reckon it's a 15-20K exercise to have it done properly.
you will be suprised with the rb30 rods aswell
turbo guys have had them in 8000+rpm in 25/30 and 26/30's boosting big numbers no worries
that is true ash, however an NA car would sit at higher revs for far longer than any turbo car.
NA = revs = power
again be weary with the harmonics issue that the RB30s are supposed to have. not as simple as throwing rods in and voila. knifeblading the crank is also a good idea/
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
    • Being a manual, we very quickly ordered new R34 gearbox (From Nissan) and remaining parts from Kudos motorsports. Would highly recommend the team there. Ultra helpful and quick to share advice and upgrades. We are in the middle of taking the Auto out (Genuine 94,000/kms) and putting the Manual in this weekend. Part 2 of the build will include likely a Plazaman Intercooler and Plenium, Hks Exhaust with Tomei Dump (ordered).
