just looking of a cheap way to make power and i came across a nistune ecu remaping.
i know dr drift does a remaping for the 33.
but also heard about the z32 ecu that is modded to suit the 33 just wanted to no if someone knows someone that has done it and if its worth chasing down.
https://www.sau.com.au/forums/topic/216634-z32-ecu-into-r33-gtst/
rb20det ecu's are easy to remap and they can be used in r33's. its been done in WA and QLD but no tuner in NSW wants to touch the idea
also there's a member here called toshi who can send remap your r33 much cheaper than you would think. search him up and his prices / options
i rang hyperdrive in WA, hey told they dont have the setup/software etc. to remap a rb25det(R33)
he told me that the people that made up nis-tune, wer working on a way to remap rb25det...
and i asked him if i could uses a rb20det (r32) ecu, but he said that the harness/plugs are totally different..
becoz i've heard of people in the east doind this....
dont no about this??? so if someone can confirm this....
but u would also lose the inlet VCT...
so yeah...
but someone plz confirm this...
thnx
so yeah...
thnx
http://www.skylinesaustralia.com/forums/Rb...ul-t176944.html
i've pulled out both rb20 and 25 ecu's. they look like they are a plug in matter. but will need a tune to run...
maybe i missed something but why not just use an r33 ecu, i emailed dr drift a while back and he didnt mention not being able to use my r33 ecu, is there any other reason that i have missed?
Yeah the r33 is a bit of a pain, this is apparently due to nissan changing to hitachi H8 chip.
You need a daughter board to use an emulator to enable you to make changes real time and these are unfortunately expensive.
There are guys out there that do R33 tuning but they would have an ecu with daughterboard installed to do the tune and the burn that data onto a H8
chip and put that into a 64 pin socket in your ecu.
So yes it's possible to "chip" R33 ecu's but it ain't cheap.
this is a quote i got back from dr drift, i little bit more expensive than a pfc but it has its benefits over pfc as well.
"Rough cost is $1000 for ECU modifications and bas maps to suit your mods,
and $300 - $400 for a full tune on the dyno."
Becareful talking about Benefits of STD ecu over PFC.
ALOT of people around here love them :)
Nah PFC does have better map resolution over std ecu 20 x 20 over 16 x 16.
Not enough for me though, I'd rather keep the knock retard function of the std ecu rather than a winky check engine light.
i tend to agree, apparently the pfc display will tell you there is too much knock but i wouldnt have the handset on display so i would never see it.
i know the pfc is a popular item but it seems that the std ecu just has a few more safety features that i like, this is also coming from someone who already owns a pfc.
Ah Ok, I was thinking bout using my r33 ecu but being in SA It seems easier to go a z32 ecu with nistune.
Besides nistune allows realtime tuning though consult port and dataloging, which is really what I wan't.
Yes it is real time ;) I'd assume that dr drift would intstall a daughter board into the r33 ecu you'd then use an emulator to modify the rom and then burn a new chip with your tune and your done.
Some tuners use a development ecu which has the daughterboard installed and use that to develop the tune and then burn and install a "chip" into the customers ecu.
The advantage of nistune is that you plug your laptop into your consult plug via a consult interface and make the adjustments, no emulator or programmer required.
I believe that you can use nistune on a r33 ecu with a daughter board installed.
Yes nistune does work with a cheaper emulator than I use, which means more workshops will have the ability to tune R33s in real time very soon. Also, as the R33 eprom based boards are now available, compared to the old single burn expensive H8 style processor maps, means no additional charge for retunes on new mods etc etc on eprom boarded ecus... h8 processor replacement rather than daughter boards are still a good option for those not looking at many retunes.
Sam
Edited by Dr_Drift
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
