One of my former R33's has now been sold on to another of my mates and he has plans to up the power a tad.
He's budgeting 2K and wants it to be safe. I'm asking you guys coz I haven't had a Turbo car since I sold the GTR a year ago and it's been even longer since I had the Series II R33, RB25DET with manual cog swapper.
It currently has the following power wise.
Complete turbo back exhaust
Pod filter in heat shielded custom airbox
Dual boost mode for 7psi standard.
My guess was to go something like the following - prices are guesses too.
Slidewiz type highflow turbo ~900?
Justjap style FMIC kit ~ 400?
SAFC + tune ~ 200 + 800ish?
Fuel reg/pump? no idea.
I know that's more than 2k but I assumed my prices would be wrong or that I was overcompensating parts wise.
Max power is not the issue, engine safety and drivability is.
I also considered scrapping the FMIC in favour of an R34 GT-T side mount but I was unsure of the max power these could push.
PowerFC is out of the question due to costs.
My guess for the above was a healthy 200-220rwkw's if fuel mods were also done.
Thoughts?
Cheers
Dan
https://www.sau.com.au/forums/topic/216771-2k-challenge-best-bang-for-buck/
Fuel Pump - $200
FMIC - $450 (or less from our traders i think)
S-AFC + Tune - $700 give or take
Clutch - 1k
Thats the 2350 spent, and thats over the budget with no more room for coil packs being in need of replacement (always a possibility)
I woudnt upgrade the turbo on a S-AFC only, full ECU or nothing is my view there.
And then i dont like the 'affordable' turbos... prefer my researched and proven ball bearing models
Thats my view, if it doesnt have the stock clutch then maybe spend it on a diff? Usually they let go early too and a single spinner is the pits
for the money i'd do things in order of reliability first up, i.e a good clutch, fuel pump etc, then later down the road when he's after more power, the previously mentioned mod's will come into affect and he can spend whatever he has saved up on actual power upgrade's...
my 2 cents
my list
2nd hand power fc
used jap exhaust
2nd hand blitz dual sol boost control
oh yeah :D You've listed 3 of my mods exactly :P
Whats he doing with the car? if track work
ugly as f**k jap 17x7.5-9 wheels all round (the uglier the cheaper)
235 45 17 RE55 SP2's
whiteline adjustable swaybars
That'll come to 2300 give or take, mainly dependent on how ugly/rubbish offset/damaged the rims are ;)
say hello to 5 seconds off your pb at wakefield (easily).
if you want 2k of power in an r33 with rubbish stock ecu:
second hand blitz ebc
china front mount kit
safc
tune
chuck in some sway bars for good measure. I can't help but look towards handling mods :(
Stock clutch is good for 200rwkw (just) if you are nice to it. be nice until you have another 700 or so for a clutch
Also think forward, if he wants to chase a bit more power later, dont skimp on some stuff now.
I mean if 200rwkw is all you want, no worries... but later if you decided to go further some things like the FMIC or turbo (if changed) might not be upto the task and resale poor etc
I should've been more specific about the car.
It has splitfire coilpacks already.
It has height adjustable Bilstien shocks with whiteline adjustable camber kits - I know coz I installed them when I had the car :banana: Already has dished 18's with 265's out back and 235's up front.
I sold the car with an Exedy heavy duty clutch, but I don't think it was installed or passed on to this owner so clutch could be an issue.
So you guys are not recommending a cheapy highflow? I'd of thought he'd make more power with a highflow and safc than the stock turbo and a powerFC, plus the stocker isn't gonna push more than 12-13 for very long, it's the original turbo on a car that's done close to 90k's mind you it's never been boosted beyond 7 while I had it or my mate after me and from what I know the current owner, another mate, hasn't boosted it either.
I was under the impression getting a PFC tuned was in the range of 1k, especially where we are - Albury/Wodonga region - though travel to Melb is not out of the question. That'd eat up the 2k pretty damn quick.
Plus I'm not sure if he plans to go further beyond this round of mods. Keep the ideas coming guys and I'll dig up some more info.
Cheers
Cheers
Ive quite sucessfully ran the base map on the power fc with some mixture correction (use injector tables). They run quite a good STD map its just a little rich. Did this on our STD turbo dyno winning GTR at SAU dyno day and made 287KW at the tyres with minimal knock. To prove a point i initialised the power fc and with six adjustments (each injector) made the same power. So no need to go for a full tune on a street car if you know what your doing.
Edited by DiRTgarage
I think thats quite risky...
You would...timing figures are quite conservative and fueling is excessive on the base map. Leaning off each injector is quite a safe method and we have double checked this method on a dyno with AFR meter and found it to be just fine.
a lot better than running a stock ecu and with boost levels up to 1 bar will be quite OK.
but...not a thing to tinker with if you are not confident on what you are doing.
this method is no more risky than running a STD ECU in your car using Aust. fuel
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
