I have picked up this arvo my new ride R32 GTR in nice all white with unmarked 5 spoke NSgt2 rims.
I bought the car from Carizma in Melbourne and it arrived here as it's being descibed with no nasty suprises......... so far.
i was beside myself when Ceva rang me (car carriers) that it's ready for pick up.
I felt so empty since my black gtst was sold and so uncomplete. I'm all good now and the fun starts here Wooohooo.
I'm baaack.
I just had to share this with you since my wife is not happy for me (she can't see the diff. WTF?? beetwen cars)
Happy Dave :P:P:(
https://www.sau.com.au/forums/topic/217435-my-new-baby-arrived-today/
I'm baaack.
Happy Dave :D:ban::banana:
Good luck looks like a sweet ride , I love my R32'S :P
judging by ur avitar it looks like an awesome beast! i remember how i felt when i bought mine 6 months ago, now i just look at her and then check my empty bank account :( still so damn happy tho.... ill never get bored of her and the endless potential!! we also want a list of mods ! :)
as far as the misses goes... take her for a spirited run through the hills then she will be able to tell the difference hehehe
congrats on the purchase buddy, ive only had mine for two weeks now and im in love!
a word of advice, i purchased my last car (the gtst 4 door) from carizma. i found that there were a number of items that were supposed to be rectified on the car for road worthy that were simply left out. just go over your car fully (or even take it to a mechanic) to make sure its all good. i had to take mine back several times before it was road worthy.
other than that im sure these coming weeks will be full of fun for you, as they were for me!
so how much power is she making?
I agree with jenkies, a decent run around some twisties will have the missus saying GTR FTW!!!
... or she will hate you for scaring the crap out of her... one or the other.
You can tell its had a basic respray. I would have cleaned the engine bay of the primer and paint dust before i sold it though :D
But congrats mate all the same. Turn the wick up on that thing.
Thanks namo, I know she's not perfect example and yes it is basic respray but I guess you always get what you pay for.
For the money it's OK and I'll clean it up a bit.
I've already had to replace main switch for lights and fix the side skirts and it apears (making noise when cold) that I will need new starter motor as well just for starters.
Oh and I hate the coil overs (JIC) great for track not for Sydney roads. Also twin plate cluch not very friendly in traffic!
As I said before the fun has begun. *being sarcastic*
Long live the king...
Dave :bunny:
Very Nice Dave!!
Massive fan of White R32 GTR's
Looks awesome!! Will we see it on the track any time soon?
Not quite yet as I need to check everything and service so it doesn't wimp out on me at the outing I would hate that.
However I will need to wait so I can save some money as my budget for my play toy is empty. :D
Dave
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
