  • Replies 183
Posted Images
Awesome weekend & teh STI ran flawlessly!
Thanks to all the volunteers & to snowman for hitting a cone & managing a WD! :-p
I have vague flashbacks of last night when Norton & I discussed starting our own little Team Jew club...
My head is still hurting :-(
Daz.
another ace weekend.
that was one of the more fun & relaxing decas for me. (trailer ftw). i dont think we can beat the upsidedown christmas tree with the 3/4 skidpan slide map.
there was a fair bit of ace steering going on too!! standout was Russ in his 32! im keen to see how you go in the results, every time i watched you there were perfect slides left right and center. It was also fun jumping in some of the dattos on the back track. my god troys green dat hauls in a straight line!
I have seen Bigbirds photos and theres some awesome shots. from what i understand between him, sarah and joel there are like 5000 shots. and west, Jarrod got your off on the backtrack too... nice work!
Bring on Deca MASTERS.
Great day up at Shep! Thanks heaps to the organisers and volunteers once again.
I had a ball with the R on the skid pan. Finding boost really helps with improving times. With some semicomps, who knows what my car could do.
Battles were ace fun! Congrats to the designers!
Well i think May be the mont i got my balls back. I was feeling the pain for missing the last two DECAs :happy: I was all over the state servicing for a rally, so i think its time i get back int eh drivers seat. Though trying to pick up women in Hopetoun was a highlight of my weekend.
I WISH I GREW UP IN THE COUNTRY!
that photo of my car...
If I had my new rims
and if you caught the flames
and if my car was clean
and didnt have the big dent
would be the best photo of my car yet :(
Had to go through the pics twice to even recognise your car :nyaanyaa:
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
    • Do this, and we'll have a resource right here.
    • "Hybrid" is a meaningless term. I could not tell you what the vendor of that turbo means by "hybrid".
