To start with, you need to do some more reading.
Poncams are cams...they are made by Tomei and these cam-shafts are called Poncams as they are their baseline general performance increase product.
Cam gears will allow you to move the torque curve to a better position.
Cams will increase torque or efficiency at certain levels, there is many different cam profiles available and each does a different thing.
What mods do you have?
The car already has exhaust,ebc and clutch. Looking at modifying the car for the least amount of money for the max amount of power without scarificing reliabilty. Will definetly add computer - they say with computer,ebc, exhaust and 1bar boost i should get about 250rwkw.I was told with cams gears as well i might get 270rwkw ,( no cams were mentioned though ). Any more power , then thats where more bucks are needed like turbos, injectors, fuel pump etc. I don't want to spend excessive money to get a little more power if u know waht i mean . A pfc and tune will cost me 1500 and cam gears about 1500 . So for 3k i could get up to 270 rwkw .On a stock engine i think 300rwkw with be about the max even with aftermarkerket turboes, inj and pump added ( which would cost another 5k for 30 kw.
cheers
cheers
Inexpensive, Fast and Relliable. Pick any 2. :happy:
Your not going to get anywhere near 250kw with the stock turbo, let alone 270. 1bar of boost on the stock turbo isn't going to do wonders for it as well.
I am running 11psi, Front mount, Full 3" exhaust, POD filter and PFC. Last dyno, which was without the PFC (had a S-AFC 2) got me 217kw. And I am quite sure it was a fairly high reading. I would expect I have something more like 200-210kw.
People running bigger turbo's, like the GT-RS are netting around 250rwkw, maybe a bit more. And thats with bigger injectors and a tuned PFC.
Hate to tell you mate but $3k isn't going to get you 250kw. Not by a long shot.
Mate not only do you need to factor in a bigger turbo to get the 250rwkw number, you'll also need upgraded fuel pumps and depending on what injectors you go for (or remain standard) the fuel pressure will need fiddling...
$3k? maybe look at a r34 smic and finish the rest of your exhaust off, hi-flo cat dumps etc... Or spend it on handlign and the car will feel heaps better
"On a stock engine i think 300rwkw with be about the max even with aftermarkerket turboes, inj and pump added "
I assumed from this statement he was talking about the RB25DET's issues with 300kw and above. Aftermarket turbo's pump and inj on an RB26 would net far more than 300kw wouldn't it? Not sure either but don't the 26's easily handle above 300 with stock internals?
  • 3 weeks later...
my r32 gtr has 241kw @ all 4s at 1 bar with stock turbos, greddy cam gears, hks dumps, bee-r front pipe and custom 3inch cat back with straight pipes, apexi pfc, trust 100mm fmic
tuned and powered at protek automotive
maybe this helps
and you will need around 6gz+ to get 300rwkw on a gtr and thats including all the mods to your gtr
best upgrade for standard GTR ( well R32 at least ) is programable ECU, adjustable cam gears on standard cams ( 4 degrees retard on inlet 2 degrees advance on exhaust if i remember correctly )then tune lifting boost. Boost level will be dependent on the turbos the car has, not sure whats a safe level for R34 turbos?
This is going to set you back over 2k though.
  • 4 months later...
Inexpensive, Fast and Relliable. Pick any 2. :thumbsup:
haha my 32R has 700cc injectors, walbro fuel pump, t -piece, cat back exhaust, pods and is making 246kwatw on 1bar with a daughterboard
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
