The 60 is when the oil is cold and you want your oil to be think on cold start to protect the engine from wear. is more the smaller number that is inportant because that is the thickness when hot which is what your engine spends most of it's time being. If you look at what nissan suggests for our climate and they recomend 10W-30/40/50. For 5W-?? the climate they suggest for this is around 10 degree max. If i was on my computer i could post the chart up from the manual, i can do it later if people are interested.
Edited by D_stirls
I think you have that totally backwards.
The lower number is how the oil acts when cold (in the case of a 10-60 weight oil the oil acts as if it is a 10 weight oil (thin) when cold.
The higher number "60" reacts the same as a 60 weight oil (thick) when hot.
All engine oils get thinner when hot, so the oil will not be physically thicker when hot.
When cold you need a light oil to move from the sump to all the parts that need the oil to lubricate. In a freezing temperature climate ie Canberra in Winter 5w engine oils assist in starting the car and limiting engine wear.
Most of the engine wear on a normal car occurs at startup where there is limited lubrication.
Better re-read that chart.
Yep sorry i have the numbers around the wrong way;
But here's the chart;
The 10 or 10W is not a viscosity its a cold pouring index . So 20w50 is not 20 weight oil when its cold .
Synthetic oil is supposed to be quite "thin" when it's cold like very cold and this would be a huge advantage at start up .
Plenty of people like the Edge 10w60 but if the 60 number scares you Mobil do a synthetic 15w50 from memory .
If I was pushing a turbo engine hard and for any length of time I'd use the 10w60 too .
A .
    • Your both right, it may hold a bit longer then.  Soon I need to change the synchros, should I fit the billet plate while I'm at it? Or just a waste of money?
    • Some of the east coast US Stagea got together this past weekend at Lime Rock Park in CT for Grid Life Circuit Legends. This is probably my favorite pic of the shoot with @Morgan.Mundahl on IG. Hope we get more stags out next year! i think I spotted 5 other than my own at the event.
    • Hi Cody, If you are looking for a simple "bolt in bolt out" solution, I may be able to help via trade. I'm swapping my auto RS4V from stock subframe to a reinforced S14 Rear subframe specifically for track duty. I was looking into different rear core options while the car was in air and I found your thread.   My VLSD rear is freshly changed fluid/inspected. I will say even with Redline diff fluid it is still not as aggressive as I would like with the "sports" viscous core, and coming from a heavily modded evo with full drivetrain I'm looking for a bit more rotation with the throttle.  I second this, the polyurethane bushings are pretty aggressive as is.  If you're interested in the trade, I am driving out to Chicago in September for a time attack event. I could swing by and make the trade somewhere Sept 12-13th or 15-16th if you are interested and you have not already solved this issue yourself.
    • No, the panel filter is the standard dry one. Yes, I did clean the AFM with electrical contact cleaner.
