  • Replies 41
Absolutely AWESOME work, Brad! I was just thinking about you the other day, 'cos I haven't seen you post for a while.
Good to see you're still keeping up with maintaining and improving the car, and giving it a good run once in a while.
thanks for all the kind words everyone :blush:
thanks Paul (DirtGarage) i have already been told i need a tailshaft loop, 4 point harness, battery isolator switch and ANDRA license before i can race again.
I dont know how far i wanna go yet, i have plenty more left in the engine and alot of people laughed when i said im aiming for 10s in it, its my main goal for the car then im 90% set on putting the motor into a 32 gtr to do more track work and drags, i dont think the stagea will cop a full rollcage so ill only get one go at a 10 before im banned :ermm:
i wasnt really a huge fan of draging the car and thought it would be rather boring once i do a time but i really enjoyed it :whistling:
thanks for the pics too dodgsun
Edited by unique1
well go out in style brad
get all the necessary stuff to run again, but this time get some drag radials (on some 16's if they'll clear the brakes) and just go out on a WAW night and just practice launching
back of half track, run 11+, then when you feel confident let er rip and give us a slip that says 10.6 or something crazy like that
Well done Brad.... isn't there any way that you can return it to AWD. That'd get rid of most of the wheelspin factor. Don't you think that the Transfer box would take it? Or do you think that it would sap that much power that it isn't worth it?
Pity, I was nearly gonna go down there on Sunday.......... just didn't happen, but if I'd known that you were running, I would have been there.
Running it in 4WD wouldn't take any extra power, only dyno power is affected, not in the real world. Let's face it, the front wheels have to be rotated, whether that is done directly by 4WD or indirectly by the road. So 4WD doesn't really affect how much horsepower it takes to make the car accelerate down the track.
The most power difference I have seen in a Skyline between 2WD and 4WD on the same dyno is ~25 hp, of which a goodly proportion would be turning the front wheels and the front dyno rollers. What's left is hardly significant, especially in Brad's case.
Something to think about.
Cheers
Gary
the car was in 4wd all day at drags and traction was still a major issue in 1st and 2nd gear i am thinking of fitting up some r comp tyres or nittos, etc for next drag runs to help it along quicker.
Yes i seen that Magna wagon, how did it get home in the end?
Ztuned yes thats the engine bay :)
omg ultimate sleeper. if u don't mind me posting pix from the last day cruise
pretty sure that your engine bay right?
ohhh shiny
shiny enough to see the people standing around looking at it :)
good move with getting new tyres ;)
they even called it a magna too :)
made up for it when it spanked a modded stagea though. :(
I had the same comment from the owner of a higly modified supercharged, Nos'd, tubbed LS2 owner. He was real proud, as are you I guess.
i would have thought a legnum with an exhaust, and a stagea with a few other mods would be a fair comparison... o_O
Unfortunately when you put 15psi in a s2 you have hit the boost cut. And she slows bad . But i drove home and the leggy got home very difficultly . But 14.5 consistently all day in AWD class and to take out the championship me be very happy with my slow stag .
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
