Hi,
Has anyone got an ignition map which i could compare to mine? got way too low power output on the dynapack today.
My tuner wasn't sure how much ignition the RB25DET could deal with.
So this is my ignition map, got 383RWHP and 390 NM of tourque @ 1.4 bars on a GT3582R
If any one has got a 400++ RWHP ignition map, could you please share it with me?
On PM or in this thread.
Thanks,
Stian
Hey
There must be something wrong there. my engine made 400rwhp on 17psi.
Here is my old timing map when my car made 487rwhp.
If your tuner is not sure what timing a rb25det can take then i would be worried if i was you. Every engine takes different timing. Different configurations = different tuning.
That was 24psi with a GT3582r to make 487rwhp.
This tune was back in the day when i used to run huge timing on cruise.
I remember on 17psi or 16 i think it was with 18deg timing it made 406rwhp.. stock cams
too early in the power range for valve float....
I think its something simple. check cam timing... what kind of exaust / manifolds are you using ?
what computer is that ? haltach or autronic or something?
anyway post up the setup of your car and we might be able to help track the issue down.
have you tried running the car on the dyno with the exaust dropped just before the cat?
try that
try that
Hi,
This is the engine:
· 1.6 mm Greddy Head Gasket
· HKS Timing Belt
· Greddy Plenum
· Splitfire Coils
· Tomei Poncams
· Tial 44 mm Wastegate
· XS power style exhaust manifold
· Garrett GT3582R A/R .82
· FMIC
· Nismo 555cc Injectors
· Walbro 255 l/m in tank fuel pump
· HKS air filter
· 3” elbow/downpipe, with cat replacer.
· 3" Greddy cat back
Running with NGK BCPR7ES spark plugs, 0.9 mm gap.
My computer is GTSlink.
Going to check the cam timing later this day.
Thanks!
Hmm strange, AFR's seem allright and the power curve doesnt have any abnormal dips. It's almost as if something is holding it back. Are the cams dialed in correctly? Compression on all 6 cylinders fine? That setup should be making around 330-350kw@wheels on 1.4bar with bigger injectors :bomb_ie: What's the injector duty cycle on the 555's?
Edited by PM-R33
I'm making 235rwkw at 1.2 bar (HKS GT2535) and can only run 10 degrees of advance at full power :thumbsup: 98 Octane of course. From looking at that timing here others are running 15 degrees or more. What gives?
Edited by Ionos
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
