  • Replies 895
Well not sure what was really up with mine apart from the top board, it thought it was a link before when I tried to hook my laptop to it. Now after having the top board replaced it is registering as a vipec, and I can connect to it fine with my laptop. Didn't have to reinstall any software.
The interesting thing is ever since I had the firmware updated and a retune last year it's been missing slightly and feeling a bit rough at times, and the idle was quite low at times. I was actually starting to get really frustrated with the ecu. Now with the top board replaced on the drive home it was like the ecu of old, smooth and not one miss. Will see if it keeps up.
Can't recommend the tuner enough, has been a great help just happy this is finally resolved by the looks of it. So if anyone has a similar issue it might be your top board.
Let me guess...the tuner was Glen at ESP?
anyone who lives within an hours drive of Canberra would be bonkers to go anywhere else.
  • 3 months later...
How many people are running knock detection on the V44/Plugin ECU? And is it really worth getting put in? Car is putting out around 247-267kw at the wheels.
Hey mate, yeah i got a v88 and its running the knock detection. Good to have, cus if you get a bad batch of fuel or its a really hot day, rather than the engine pinning its head off and risking putting a hole in the piston, it retards itself and gets saved.
Already paid its price on mine when i got it tuned and it was a little bit lean in the bottom sector so didn't detonate like it would have and leave me with a nice collection of metal pieces lol. mines only putting out 210kws but yeah well worth while if you ask me as good insurance
my 2c anyway good luck with it :P Matt
  • 10 months later...
well the reason I'd run Linux is because I just bought a netbook specifically for the car, and it comes with W7 Starter which is a heap of shit OS (SO MANY FEATURES REMOVED). So I have the choice of running Windows 7 64bit which might be a little resource intensive but is the only reliable "free" version I can get, or Ubuntu which is free anyway. Might look into an emulator for ubuntu, otherwise I'll just see how W7 64 bit holds up on a 1.6GHz dual core w/ 1GB ram lol
32bit. i am highly doubtful the atom is 64bit capable.
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
