Hey all,
As title says its a dec 95 model Black manual, has done 83,000km's (imported with 73.500km's!! Basically driven to and from work only, bout 35km's a day) I am the first owner in aus. I have spent a lot of money on it since i got my liscence in feb, basically all mod's except for the air filter were put on by me since then. Oil changes every 3,000km's with Penzoil Race Synthetic with Penazene addative. Mods include:
-17*8" Gradu racing rims
-Custom ATP T03/4 turbo
-Custom AVO bar and plate front mounted intercooler with polished mandrel bent alloy piping, no welded joins (cooler polished aswell) and Hose Techniques blue silicon joins
-3" dump pipe off turbo to cat into a genuine 3" Fujitsubo LegalisR exhaust
-K&N M's high power air filter
-HKS turbo timer
-AUtometer ultra-lite pro comp gauges
-Custom alloy catch can all polished with braided fittings
-Razo race gear knob and Razo race pedals
-Custom dash switch panel covered in pearl white vinyl.
-Odyssey dry cell battery
-Nismo belt pads on all belts, and Nismo hand brake pad
-Pioneer head unit, front splits, 6*9's running off 600wAmp, boot wired ready for big sub set up, previously had a huge system in it, and have left all brand new cabling ready for new subs/amps. Also has false floor fitted with all panels and wheel well filled with dacron to kill dead sound and improve sound quality.
Just took some new photos, show its real beuty :P Also thought i'd add i have had the timing belt and all axilery belts changed, front urethane castor rod bushes and a new o2 sensor fitted so she is absolutely puuuuuuuuuurring!!. Also now has 12 months of reg to... so can't complain at all peoples!!
http://www.angelfire.com/co3/thegrub1/inde...dexskypics.html
If interested, and can meet in Melbourne to view.
https://www.sau.com.au/forums/topic/21822-nice-black-95-gtst/
anybody who is looking for a decent skyline would be stupid not to buy this car with the mods its got on it, for that price..
you're all stupid buyers out there :P
YBSLO4: you can slip me the $50 later :D
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
