Hi all,
After looking at ebay and Play Asia i cant seem to find an uncut version of GTA4 that will be pal compatible for my XBOX 360. Can someone give me a link to a place where i would find an uncut copy?
CHEERS
Are these region 4??
Will the UK version work on our XBOXs?
GAMES ARE NOT REGION CODED, there is Pal(aus) and two types of ntsc. UK is pal so it will work 100%
region coding is for dvd's
I got mine off ebay it cost me $65 including shipping and took two days on normal postage, however seems as though some people didi not get there copies and left some bad feedback so i would go with what Skyrin3 did and get it there.
I would recommend just getting one from big w for $78 as i believe a uncensored one is not warranted.
There are some noticible differences between the two versions. Personally i have both, mainly because i could not wait.
I would recommend getting the uncut version if you dont mind waiting a week to get your copy.
www.game.co.uk
UK is PAL and PAL will work on your australian xbox and game.co.uk sell only the R18+ version of the game. You have nothing to worry about.
That GAME UK has some good deals.
PS3 with GT5 and GTA4 for $700AUD delivered. Guess what im getting next month lol
I wouldnt buy a PS3 from overseas. Yes games will work, but you wont be able to play blu ray movies.
There are 3 game regions, PAL, NTSC US & NTSC JP. That goes for all game consoles current & b4, except PS3 & the portable ones, which have none.
Edited by Mayuri Krab
XBOX 260 GTA4 Multiplayer is region locked as well just FYI
Multiplayer on PS3 is not region locked...
Picked up my PS3 version from Amazon but yeah the only place you can get it for 360 is the UK
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
