hey guys im wrecking this r32 gtst. im located in brisbane and all parts listed are available plus many more just sms or pm me what parts you want. the car is complete so everything is for sale. contact make on 0423 849 355
ALL GEAR WAS PUT ON IN JAP SO ALL QUALITY PARTS!
Genuine Dmax Carbon fibre bonnet VGC $1000
RB20DET motor with SS manifold 120 000 kms absolute perfect condition blows no smoke 114 000 km (major service done 10 000 km ago) $1300 (no coil packs) will seperate ss manifold
Front Tein Ha series coliovers $450
Rb20 Gearbox VGC $450
Short shift kit VGC $150
Dash - perfect $200
GTR Replica front bar $150 one mount has to be re fibreglassed on no biggy
Fuel tank $150
Door cards perfect condition $75 ea
Front switches $75 drivers 30 passenger
Sparco Steering wheel $50
Turbo Timer $50
Windshield $150
Front seats $150 Pair
Roof lining $50
Front guards $120 pair
Headlights $80
Indicators clear $80 pair
split fire coil packs $400
HKS split dump front pipe and exhaust $550
Tension rod bar $120
Solid pineapples $100
2 way lsd and housing $750 (brand unknown)
Hicas lock kit $150 ( full replacement kit for lines and everything)
GTR brakes (so i am told will confirm when i pull car apart) $700
Castor arms $150
Doors Drivers(some damage) $125 passenger GC $150
K&N pod $50
Viper alarm system $80
PLUS MUCH MUCH MORE! just ask and will pm or sms! thanks heaps will have more photos and a video of the car running as it is in perfect condition when computer isnt being gay
Mike 0423 849 355
post-17389-1210394305_thumb.jpgpost-17389-1210394407_thumb.jpgpost-10298-1124278144.jpgpost-17389-1210394659_thumb.jpgpost-17389-1210394843_thumb.jpg:
https://www.sau.com.au/forums/topic/218580-wrecking-r32-brisbane/
  • Replies 55
not selling the volks as of yet, but will let you know later if we do, $150 without the bov on it, goes through stock holes, its good quality, do you by any chance have the stock bit of peipe from the turbo to the side mount ic?, cheers
http://www.skylinesaustralia.com/forums/F-...93#entry3776693
interested in trades for bonnet? looks like it will fit gtr. just added some non car parts and also got a tonne of new pc games for trade
Brakes are not GTR just GTS-T :(
Gearbox - SOLD
Castor arms - SOLD
Headlights - SOLD
catback exhaust - SOLD
radiator - SOLD
air filter and airflow meter - SOLD
short shift kit - SOLD
Edited by sly32
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
