hay all just have a few question,firstly its an rb20 and for the build i so far have r33gtr cams,crank shaft and conrods. to fit the crank and rods the engine needs to be machined?for clearances?also can get some rb26 pistons for cheap,or would i be better of getting some forgies although i am on kind of a tight buget?also what kind of displacement would this take the rb20 to +do for it torque wise?
thanks all in advance
https://www.sau.com.au/forums/topic/218619-rb20-engine-build/
more power,yes i am on a tight buget but have a brother that owns an engine reco workshop ie can do all the engine machining block blue printing ect.......for free and have a friend thats a good machanic that is gonna pull down the engine with me and put it all back together.+have alot of the parts for it already.
You can either get Tomei 2.4L pistons which i think are 82 or 83mm or you can try some custom cosworth etc pistons. The head gasket will msot likely be Tomei as well to suit the new bore.
Do a search for RB24, you should be able to get plenty of good infto. Particulary from Legend01 who built a nice 3000rwkws example
thanks for all the input,was just asking about the pistons gtr didn know the difference in size(bore).buget don't really have one just don't want to go stuiped.as i have just purchased a 2way and coilovers and in the process of buying a turbo 2530 maybe 2535 or 40 considering the build,thoughts?
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
