hey guyz/girls, im just wondering what the R35 GTR will look like? and what engines will be packed into it?
I've heard so many stories about this and that, and im not sure if theyre all rumours or not? (also made a few bets to my friend abt it :D )
I've heard its already sold in japan as a family car with four doors and a non-turbo engine? Because Nissan is losing money and they want to appeal to a wider market so they made it a family car? what the hell.
another, V8? or V6 twin turbo???
Will it have the four circle lights that makes skylines look so appealing!?
Is the shape and engine even confirm? or are they still deciding on it???
check this site out: I DONT BELIEVE IT!!
http://www.webwombat.com.au/motoring/news_...ts/4_02_nis.htm
thanks for the inputs in advance!!
https://www.sau.com.au/forums/topic/21906-r35-whats-the-deal/
Im not too sure about the site but so far i have only seen a short clip of the concept V35 GTR on one of the Mishief videos, it held a strong reesmblance to the Z at the front. Along with the rumours I have heard that its a twin turbo V8.
If i can figure out how to get screen shots of it i'll put up a couple.
i've read rumours that it'll be using the same block as the 350Z - which if it is should be very exciting as the VQ35DE cranks "only" 208kW. equip the twin turbos and the VQ35DETT should be seeing a lot more than the Jap limit of 208kW - maybe 300? :D
Also I think the GT-R will have the different shape than the link about... I'm guessing something cross between a R34 and the 350Z...it will be an outrage if the R35 GT-R doesn't have the tail lights!
I don't know why that article refers to the new skyline as an *R*35... when it's quite obvious that the new Skyline is a V6 VQ engine. It's V35 :D
Have a look at this thread...
It should tell you all the latest info up to July and some pics of the engine and other stuff.
in the new speed magazine it says the American's will get a V8 where as the aussie/ japan will get twin turbo V6 from 350Z. the concepts are all here and there! the V35 out in japan doesnt look nething like a skyline however the GTR is said to be just GTR not skyline GTR, and it is meant to have the Stove burners (hopefully) will be a killer when it comes out
>akeenan: TMS will be open to the public from 25th October to the 5th of November at the Makuhari Messe in Chiba.
>nismoman18: Would you be able to post up some scans of the article and pics of the Speed Magazine GT-R story? I've looked high and low, BUT I CANT FIND ANYTHING about a V8 "GT-R"!!!:( Some other members said they'd post some reports, but I guess they forgot.
No kidding, in Japan, there is NOTHING to say about a proposed V8 engine in a Skyline, let alone a GT-R... yet I hear rumours (especially from Oz and the US) that a V8 is a definate. Please could somebody shed some light on the source of the V8 GT-R rumour?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
