Hi Guys.
I have a little plan with my new Stag,. the RS-Four V, to make more then 800 hp.
I will buy a HKS 2,8L strokerkit (Support 1200 hp), cams, cam-gears, springs, bigger valves, get the top ported, a HKS SPL51 Kai turbo.
Clutch will be a Exedy trible, Nismo water and fuel-pump.
What more do i need, i ask about importend parts to make this, i know all about fueling, ECU and stuff like that, but engine-parts in the RB25DET.!!
Edited by Stagea Denmark
HKS T51R SPL is the 1000hp turbo
HKS T51R KAI is the 800hp turbo.
I would say dry sump setup if you are going to be spending that type of money.
Strip the interior.
Cage.
And the best of luck :P
800hp+ out of a 25? :D
Is that even possible? Wouldn't you be much better off flicking the 25 and starting over with a built 26 or even a 30/26?
Where is the differend, building a 2,5, 2,6 or 3.0 liters engine, the Strokerkit is build for the RB26DETT aswell.!!
Thank you for allowing me to provide you with a quote for the products listed below. Let me know if you want us to ship them to you. Take care.
Qty = 1, Nissan Skyline ARP Pro Series Main Studs GTR RB26DETT ARP 2000
Qty = 1, Nissan Skyline (89-98) ARP Head Studs RB20/25 DET head stud kit
Qty = 1, Nissan Skyline Exedy Lightweight Racing Flywheels
Qty = 1, Nissan Skyline TOMEI Metal Head Gaskets RB25DE(T) 88.0-1.2mm
Qty = 1, Nissan Skyline TOMEI Valve Springs R33 RB25DE(T) A-TYPE
Qty = 1, Nissan Skyline TOMEI Pro Cams RB25/RB20 SOLID IN 260-9.25
Qty = 1, Nissan Skyline TOMEI Pro Cams RB25/RB20 SOLID EX 260-9.25
Qty = 1, Nissan Skyline TOMEI Timing Belts RB26/RB25/RB20
Qty = 1, Nissan Skyline TOMEI Adjustable Cam Gears Set RB20/25/26
Qty = 1, Nissan Skyline TOMEI Rb28Kit Stroker Kits 86.5 BNR32/BCNR33/BNR34
Products $8,875.54
Total $8,875.54
well, torque, for a start. Go for a RB30 block, grab one of the new 3.4lt stroker kits and slap on the biggest child-swallowing sized tubo you can find
step 3 - profit!!
step 3 - profit!!
nice one, anon...
But yeah definitely go for an RB30 (obviously a 3L block) to start. Then if you want it bigger, stroke it. Will allow you to spool up a turbo much quicker, as well as more torque down low. No poin starting with a 2.5 when you can start with a 3.0.
nice one, anon...
Correct, i know, but we have some strange rules in Danmark, you are not allowed to tune your engine, even not drive with a open air-filter box.
So, i have to do it on a standard RB25 block, and make the max out of this engine.
This treat was about what to be aware of, what to change in the engine, i know the oil and water pump have to be changed to Nismo, what more.!
What kind of turbo-setup i will make, i am not sure, a big HKS turbo, or a twin turbo setup, to make a faster spool.!
Edit: After searching the internet, i found out the RB30 Block fit together with the top from a RB25, then i can get my car approved and make it legal in Denmark, i also found out, i can get a Nismo400R engine.!!
yeah... if you were going to change to a 3.0l block, noone would even be able to tell, except for the power.
Realistically you should be asking these questions in the forced induction performance area, as it has nothing to do with stageas, and everything to do with forced induction performance. I think this thread should be moved.
You will also find that if it were in that area, you will get a lot more replies with a lot more useful information.
But none of the kitteh pics.. :D
hey mate, if your talking 800hp at the wheels then i dont know how long a rb25 block will hold up and i'd be looking at a rb26 n1 block for that power, also 260 degree cams are abit small, u would be expecting 272 and around 10.5mm lift for that power. Bolting a 800hp turbo on doesnt mean u will make 800hp either, u will need the 1000hp one for 800rwhp.
u will need a ati balancer, jun/tomei oil pump, n1 water pump if your gonna rev it alot, rear head oil drain, massive 10L baffled sump and every other possible mod for a rb engine to push that power.
if your talking 800hp at engine then u still need most of that stuff but it will be much easier to achieve, thats why every gtr with a t51r isnt making that sort of power, its more than the sum of the parts to push those figures. You will also need to run it on race fuel if your planning on a reliable 800hp. The gearbox will be useless and u either need a 20k holinger or ppg dogbox (around 15k all up), diff will not be so good either, also axles/unijoints need to be upgraded, gtr stuff at a minimum. brake upgrade also is a good idea
trust me there is alot more to upgrade than just the engine if u want that sort of power, driveline wont last 5 min as it is.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
