hey guys, just saw on another forum that those cheapies are down to $77 (the ones from supercheap auto). now what i want to know, is there any way to run both in parralel to one air line. maybe have each reg on the compressor, run hose from each comp to an external reg, then a single hose from that to tools/spray gun etc.
now what i need to know, does such a thing exist, the two in, one out reg? i would still like to leave to two regs on the compressor becaause i dont want to rely on any hose to hold full pressure from the tank, would like to have reg on the tank, maybe set them both 10psi above the 3rd, in line reg?
any idea on current draw also (hard tof ind date on the cheapies)? i've heard there can be issues with tripping switches if they both turn on at once, not sucha big issue for me, just worried about overall current draw?
cheers,
Ben
https://www.sau.com.au/forums/topic/219218-who-knows-about-air-compressors/
Exactly what are you trying to acheive though?
Flow or pressure?
flow + tank capacity. mainly a decent free-air delivery rate, at a reasonable price (ie i'm a cheap motherf*cker)
i could run hose between the tanks and then a reg, but im just worried about running such high pressure through hose, i prefer to have low pressure through the hoses only... probly more a mental thing than anything, im sure you can get decent high pressure hose, but it'd still make me nervous lol
Edited by VB-
i have considered buying a couple of these second hand, pulling the motors off them and putting them on a gas tank from the wreckers, that way you would get the volume and the same pressure, maybe even change the gearing on the motors as well so it will fill the tank quicker.
For the love of crumbcake, DONT mess with these little cheap compressors, especially with changing gearing. They are not built for it and can blow up if messed with. Also, gas tanks use a completely different set of connections to compressed air, and this is for a very good reason. They are not meant to deal with the amount of water and thus rust that a compressed air system will generate.
If you are setting this up in a garage, a neat trick I used a few times in setting up compressors that were a little small, was to hardline the recievers to a ring main - ie a steel pipe running the circumfrence of the workshop that acts as a secondary reciever. You could easily put 2 cheap compressors in the circuit, with a cheap and simple reg between the compressor and the ring main, and then just bung in a couple of take off points.
Few things to consider when you do this, make sure the ring main isn't mounted dead flat, and have at least one drop leg at the lowest point for condensation collection.
Only ever take your air points from the top of the ring main to avoid any excess water getting to your tools.
Only use screwed fittings, not welded as they are a LOT less likely to sufer catastrophic failure (go bang) and are much easier to seal.
Use a QUALITY air dryer/lubrication set up AFTER the ring main. Don't go cheap here, as it will just cost you money and heartache when all your air tools start crapping themselves.
Make sure you drain both the tanks and ring main at the end of every day.
thats just an even better reason to try it :whistling:
maybe use a dryer set up from a truck, they have a filter between the air compresor and the tank used for the air brakes.
whats the go with fitting more storage space, ie a gas tank? surely you could buy screw in adapters to make it all work without doing anything dodgy/dangerous?
Not really, CNG and Nat Gas actually use their very own thread form to stop people from using the wrong spec fittings in them. Ever noticed how your BBQ gas bottle has a left hand thread...?
If this is definately the way you want to go, try an air tank out of a truck braking system or something similar.
yeah where would i look for something like that? dont really know of any truck wreckers, but im assuming thats all i'd need to find?
with LPG bottles, you should be able to get a fitting from somewhere, maybe just butcher one up?
semi-on-topic... i got a couple of fittings around to fill BBQ bottles with LPG (dont tell me it cant be done, im sick of hearing it, BBQ has been rejetted to suit), one of em even looks like a factory bit (ie not butchered). are automotive LPG bottles the same as BBQ ones? i cant think of any other possible place that it would come from?
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
