hey guys, just saw on another forum that those cheapies are down to $77 (the ones from supercheap auto). now what i want to know, is there any way to run both in parralel to one air line. maybe have each reg on the compressor, run hose from each comp to an external reg, then a single hose from that to tools/spray gun etc.
now what i need to know, does such a thing exist, the two in, one out reg? i would still like to leave to two regs on the compressor becaause i dont want to rely on any hose to hold full pressure from the tank, would like to have reg on the tank, maybe set them both 10psi above the 3rd, in line reg?
any idea on current draw also (hard tof ind date on the cheapies)? i've heard there can be issues with tripping switches if they both turn on at once, not sucha big issue for me, just worried about overall current draw?
cheers,
Ben
https://www.sau.com.au/forums/topic/219218-who-knows-about-air-compressors/
Exactly what are you trying to acheive though?
Flow or pressure?
flow + tank capacity. mainly a decent free-air delivery rate, at a reasonable price (ie i'm a cheap motherf*cker)
i could run hose between the tanks and then a reg, but im just worried about running such high pressure through hose, i prefer to have low pressure through the hoses only... probly more a mental thing than anything, im sure you can get decent high pressure hose, but it'd still make me nervous lol
Edited by VB-
i have considered buying a couple of these second hand, pulling the motors off them and putting them on a gas tank from the wreckers, that way you would get the volume and the same pressure, maybe even change the gearing on the motors as well so it will fill the tank quicker.
For the love of crumbcake, DONT mess with these little cheap compressors, especially with changing gearing. They are not built for it and can blow up if messed with. Also, gas tanks use a completely different set of connections to compressed air, and this is for a very good reason. They are not meant to deal with the amount of water and thus rust that a compressed air system will generate.
If you are setting this up in a garage, a neat trick I used a few times in setting up compressors that were a little small, was to hardline the recievers to a ring main - ie a steel pipe running the circumfrence of the workshop that acts as a secondary reciever. You could easily put 2 cheap compressors in the circuit, with a cheap and simple reg between the compressor and the ring main, and then just bung in a couple of take off points.
Few things to consider when you do this, make sure the ring main isn't mounted dead flat, and have at least one drop leg at the lowest point for condensation collection.
Only ever take your air points from the top of the ring main to avoid any excess water getting to your tools.
Only use screwed fittings, not welded as they are a LOT less likely to sufer catastrophic failure (go bang) and are much easier to seal.
Use a QUALITY air dryer/lubrication set up AFTER the ring main. Don't go cheap here, as it will just cost you money and heartache when all your air tools start crapping themselves.
Make sure you drain both the tanks and ring main at the end of every day.
thats just an even better reason to try it :whistling:
maybe use a dryer set up from a truck, they have a filter between the air compresor and the tank used for the air brakes.
whats the go with fitting more storage space, ie a gas tank? surely you could buy screw in adapters to make it all work without doing anything dodgy/dangerous?
Not really, CNG and Nat Gas actually use their very own thread form to stop people from using the wrong spec fittings in them. Ever noticed how your BBQ gas bottle has a left hand thread...?
If this is definately the way you want to go, try an air tank out of a truck braking system or something similar.
yeah where would i look for something like that? dont really know of any truck wreckers, but im assuming thats all i'd need to find?
with LPG bottles, you should be able to get a fitting from somewhere, maybe just butcher one up?
semi-on-topic... i got a couple of fittings around to fill BBQ bottles with LPG (dont tell me it cant be done, im sick of hearing it, BBQ has been rejetted to suit), one of em even looks like a factory bit (ie not butchered). are automotive LPG bottles the same as BBQ ones? i cant think of any other possible place that it would come from?
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
