QUOTE(yellow submarine @ 17 May 2008, 07:29 AM)
What about a HKS GT2535? Do they have good response and power?
It is a responsive turbo but you will probably be hitting 250-270 rwkws? depending on mods.
I have the HKS GT2535 on an RB25DET makin 240rwkw pretty responsive turbo very happy with it. In the process of getin injectors, z32 afm and fpr then uppin the boost to 17 psi from 15psi hopefully pull abit more power out of it. Good turbo if ur only chasin the 240rwkw mark fun and responsive :) Also it fits under the standard heat shield very nicely :)
Edited by iLEC
Yeah a bit dumb I know, I saw that post again after posting my comment then re-reading the thread. Oh well.
I have narrowed it down to the GT2535 and the GTRS. Does anyone know the difference and response of these 2? If they are similar I will just go the cheaper path, though I am leaning toward the GTRS.
On the R34GTT we ran a GCG ball bearing high flow and it make 270 rwkw with very good response. In fact, as I have posted many times, it made more power everywhwere, from idle to redline, than it did when it was standard. It was so good for what we do, I have just fitted another one (R34GTT high flow) to the rebuilt RB25.5DET in the R33GTST.
Cheers
Gary
Yeah Sydneykid, what boost and what supporting mods? I've got;
  • Blitz turbo back exhaust
  • Blitz front mount
  • Nismo oil cooler
  • Power FC
And I am getting;
  • 550cc injectors
  • Bosch in tank fuel pump.
Would I be looking at a similar power figure with a good tune? Because if I am, then i'll just go a GCG hi-flow.
Cheers
Gary
thats what I'm running with the same result. response is great...power is good and runs a good 116MPH down the strip...which is good for a low 12 if u can launch properly.
You'll be happy with either. Both GTRS and a high flow are straight bolt on. The GTRS will need the oil lines replaced with the supplied ones and the high flow won't.
In the end regardless of the difference in reponse/power I doubt you'll notice it.
You'll be happy either way I recon.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
