oh, rev limiters kill the pumps too. if you have a "soft cut" limiter its not as bad. but a hard cut. (power fc) wont be helping. your crank is ok. it just dont like the revs and or limiter. and if you are reving it past 7k id be getting a better balancer. a r33 gtr n1 one at least :starwars:
What would you define a "soft cut" and a "hard cut" as?
  • Replies 68
Can someone tell me by looking at this list what partnumber would be needed for a r32 gtr with r34 n1 engine
probably somewhere near 400kw, and is going to be pretty much a race only car with next to no street use.
http://www.atiperformanceproducts.com/prod...s/damnissan.htm
I've gotta get one of these before i put the motor in.
this is for Ati damper.
Cheers
Just as a side note the guy who builds (or used to build) kier wilsons GTR motors at wilall works at outlaw speed shop now. He says kiers car was running the "cheaper" of the 2 ATI balancers and was fine. So thats the one i went with.
This thread is making me want to buy an ATI balancer. Can i just put one on while my motor is out or will it need to be balanced with the engine internals again?
haha you and me both..
when they are back online (down for a big update)
http://www.horsepowerparts.com/
have them for a nice price... unless you can find better price
p.s. Cheers Alex..
Edited by Angus Smart
p.s. Cheers Alex..
I have seen those guys before, cheap prices. I ended up buying one from my local supplier for 700, more expensive but I support them as when i buy other parts like lots of speed flow fittings i can bring them back if they are the wrong ones etc.
My build if very basic with N1 pump but im going to balance the bottom end and run the ati balancer, hopefully will give me no dramas.
Cheers
Just bolt it on, they are balanced from the factory, unless the machine shop used your existing balancer to rectify any other imbalances
I spoke to a bloke at Ross Tuffbond today in regards to one of their balancers. I think for many of our applications (mostly street driven sub 400kw cars), the Ross balancers are more than suitable. While the ATI ones seem like an excellent product, theyre also very expensive at over $800 in Australia. Although i have come across new ati balancers on ebay for about US$350 + $100 postage, but these were for chevy V8's etc. Im yet to get an email back from them as to whether they can get RB26 ones for the same price.
Anyway, the guy from Ross said they've developed a pulley that attaches to the harmonic balancer that drives an external oil pump used in a dry sump set up. Im thinking of heading down this path eventually in an effort to bypass the poor design of the Nissan oil pump drive. I havent researched it yet, but surely it can be done for less than the price of a Jun or Tomie oil pump (>$1500!!).
Anyone know anything about dry sump set ups???
Shaun.
ati balancer for 430-490 us for rb26 listed in the site i mentioned before.. horsepower parts
now as for drysump. i been looking at it for months, and i seen the costs of your typical normal setup
jun pump 1500
enlarged sump around 1000 ?
oil return mods 300?
now as for drysump.
the pump and the lines are the killer.
atleast 1000 for lines,
and atleast 1500 for a 4 stage pump and that only goes upwards.
tho you can source used pumps and systems from nascar teams in the states for rather cheep. and they have all the parts you need except lines...
check ebay usa for them..
i have since forgotten about drysumping for now
jun pump 1500
now as for drysump.
Yeah, i hear what youre saying. I just did 10 minutes of searching on this forum and quickly discovered that dry sump set ups are way out of my league.
There goes that idea!
Shaun.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
