haha have you posted these to stir everyone up Malcolm?
these are just standard cars in good condition. and a bit old.
don't get me wrong....I like them.
Hi there ! :)
Duncan Duncan ! - shame on you ! - hehe !!
No not at all ! - its this kind of thing that reeeeeeaally appeals to me. Except as mentioned id personally lose the chrome and shiny braided hoses and go for more of a factory look but hey thats just cosmetic and so so easy to adjust - but hey thats just "my" opinion.
Its the fact that after 30 to 40 years there is still examples of cars in this condition that arnt in the nissan museum. I think its great !! - in fact as i also said i dont care what type of car it is - any car in this condition is ok by me - doesnt have to be Pebble Beach Concourse just cars in immaculate condition - theres a company in the uk doing nut & bolt ground up shell dipping restorations of e-type jags but with more up to date suspension/electronics/brakes etc etc - brilliant stuff !
Its this part or facet of motoring that i feel im into most with the driving of them second - dont get me wrong i love driving but when theyre in this condition i like it that much more !!
Cheers malcolm :D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
