It need's to be fixed to the car. As in it can not be removed by any expected forces from racing.
i.e. a gauge screwed into console will hold
a 10kg object screwed in by one screw will not.
You are a smart man Jase!
Also things like suction cups I won't allow. They are really not secure.
I know people have those cameras attached to camera mounts on suction cups.
I know VZSS has one and modified it so that it was bolted in to the child safety restraints. Maybe PM him?
Just a heads up so people with these don't get cranky on the day.
  • Replies 547
Posted Images
Wakie license yes at the admin office. You might want to go through scrutineering first as you will be in one of the first groups and there will be a line.
As in bolting to the centre console?
If you could make a steal bracket and bolt it to a structural point that would be fine.
But it would be hard for me to say yes over the net for something I haven't seen. If you want we can talk about this over PM or if you come down to mikes the night before I can try and help you figure something out.
yep understand completely....I just want to use 1 or 2 thermocouple readers which would weigh 200-300grams...I'll make a bracket that will withstand at least 4g peak load which means 1-2kg force won't break it...if it passes it passes, if it doesn't it doesn't and I'll put it in the glovebox...
Do you has to have a visor fix on to the helmet?
Wahhh???? *is confused* haha we are checking for damaged helmets. aka cracks & stuff.
Yep. Come see me the night before I'll come check it out and let you know what I think. :D
Re the power point question,,,there are heaps of power points in the carports,,,no need for a long extension lead mate.
Sorry Corrine as I am not having a go at you for one minute but I always find it funny that you are not allowed to have say a pencil type camera cable tied or race taped inside the cabin. I have been to tons of race meeting and seen these cameras tied and or race taped to the outside of cars sail through scrut. Now if it is unsafe inside (which it is) why allowed them on the outside?. I'd look pretty funny with someone elses camera inbeded in my head.
Neil.
DIF
I have a suction mount camera designed for motor sport which has been used at Wakie both inside and outside of the car on an Autosports day. I assume this would be ok?
It's designed to hold onto the outside at over 150mph and i don't think i'll be getting anywhere near that. I'm not fussed on the outside of the car but will be using it on the inside.
It's called - Motorsport Hero Camera. Tiny, yet effective :laugh:
Cheers
Bobby
Same here for the camera mount I've had mine in heaps for cars at race meetings even bathurst no one said i couldn't have it in the car it was classed as safe for cams meetings. but the camera that is on the mount is like the size of a wheel nut.
Edited by motoractionservices
:geek:
Same with mine, just checked the name and it's the GoPro Hero.
Is this what you've got?
I screwed up my sound setting last time and had no sound at all!
It's even funnier that cams have no real written rules regarding cameras so they have left it up to the poor scrut to work it out. I had old man Cary Butchers (spelling) Michele's log book man design my video holder and he now points to it saying thats whats required. I've seen shift-light size ones duct taped to roofs pass scrut and all the little ones like the suction cup hero. Scary was one guy at a Powerplay day that cable tied his including the tripod to his headrest poles.
Titan,,,don't worry about the weather mate,,,it's all good for learning your race-craft. I was always worried about driving in the ran,,,now I love it!!!.
So a good idea for everybody should be to replace those old weather beaten wiper refills with some new ones.
Neil.
Wakefield are now even selling in car cameras... have a look when you sign up, they're on the shelf next to the helmets. My suction one is also rated to 150mph and has passed CAMS scrutineering in the past, but its up to the Chief Steward to make the final decision either way, so can change accordingly at their discretion.
scott, thanks for bringing the pics will be great to grab them.
re power, it is in every garage. there is air at the end of the first row of garages but no pressure gauge.
as for cameras (or anything else) the rule generally is that lipstick style cameras are OK but full handycams etc are not. this will be formalised from 1/1/09 for sure. as for suction cups I have used one to hold a full sized camera and it was not safe in my opinion, i only ever used it once. would be fine to hold a lipstick camera though they are only about 100g - even in a 5g crash that would only be 1/2kg
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
