hey guys, i am willing to help out in anyways needed (except dressing up as a girl, i said no bam bam!) heheheh anyways i am gonna send a message to GTNIK today to ask him whether he is still interested in joning us for the show :P i'll let ya's know the details tonight hopefully :)
adrian :D
  • Replies 504
Killer, We'll be more than happy to have you with us:D
Troy, I thought that the blue for the guys shirts and maybe red for the girls:D
Adrian, Do you want to enter your car? (Please)
Any offers of girls are kindly accepted, I'll put them through a rigorous selection process;)
I have spoken to Lloyd this morning and should have a map of the hall tonight which will show where we will be and the shape etc.. Was I looking into tv's???? I 'might' be able to 'borrow' a projector from work for the weekend, not sure what to do about TV's unless someone here works for a rental place....
Adam, we had a thread about the meeting, will make sure we give heaps of notice for the next one. Definately want your car inside. Ken may be entering in another display so we can't count his car just yet.
Anyone speak to Dan (Sly33) yet to see if he wants to go in with us??
Brett
Edit: Ohh and I have PS2 and GT3.. Also have Midnight Club II which I think you can link race as well.
I chose Red ..... i didnt like the MAS yellow .... yellow doesnt really look good on a chick unless shes really dark skinned .... which most of us chickies arent :P so red is fairly universal .... suits many people and stands out.
Originally posted by GTS-t VSPEC
We are also planning on having a flyer with details of SAUWA and the forum. If there is anyone who can have these printed really cheap that would be great, we're only doing them in black & white.
What he means to ask is ..... Does anyones work have a good quality photocopier :P
and brett yes u said u had a contact with a rental company thats what i figured for the TV's.
think its $10 a day per tv from radio rentals so if we have rent them thats not to much.
we need to nail down with ken if hes with us or not. and work on dan(sly33) to go with us instead of rollaboyz seeing how much hes has to spend on the car now.
October 18th ??
Well that's easy , I won't be at any display cos is the penultimate round of the Speed Event Series and can't afford to give the points away.
Sorry but didn't realise that was the date.
Possibly could come there Sunday but car will be pretty grubby.
Cheers
Ken
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
