Hi all, im going to get a r32 gtr says 49km on it, I already saw it and test drove it, it seemed fine, but should I bring it to a mechanic and get a compression test ect? also are they prone to breaking down or quite reliable if you dont drive it like mad? I have acouple mechanic friends but they never worked on a skyline before is it pretty straight forward to do the timing belt and such?
https://www.sau.com.au/forums/topic/219992-getting-a-gtr/
I think you should always get it checked out by a mechanic that knows about them. Don't just get a mate to check it if they don't know about skylines. take it to a performance mechanic.
To my knowledge they are usually pretty reliable if looked after, also depends on what mods are done and how the previous owner looked after it.
That said it is a car and cars break down!!
Good luck with it, hope it treats you well!....
https://www.sau.com.au/forums/topic/219992-getting-a-gtr/#findComment-3879414
GTR's are reliable as long as you perform maintenance in accordance with how you drive it...drive it hard=more maintenance and possible breakages. I dont drive mine as a daily driver but some guys do...I think they're too special to waste on the drudgery of work.
Get the car up on a hoist and check the underside, 49K sounds too low. Look for signs of wear and tear.
Good luck
https://www.sau.com.au/forums/topic/219992-getting-a-gtr/#findComment-3879564
Like what others have already suggested, don't pay so much attention on the km's as it is pretty much impossible to find a genuine example unless full log book has been provided. Otherwise, you just don't know the history of the car.
You should do a general overall body and chassis check 1st BEFORE even looking into the mechanical side of things as none of the other bits will help if the car has a bent or a "straightened" chassis. A majority of GTR's on the market will have some kinda of repair done to them, such as panel replacement...etc. This is fine, as long as the chassis alright.
For a general body check (BRING A GOOD FLASH LIGHT WITH YOU!!) and check the following:
- Look for uneven panel gaps around the bonnet, bumper, door, side skirts, rear bumper, rear boot lid, lights. Use your hand to feel the gap on both side of the car and see if they are the same.
- Look in the engine bay and see if there are any evidence of fresh/mismatching paint
- Check all the bolts (e.g. bonnet hinge bolt) and see if they've been turned
- Check the bog lines in the engine bay and see if they are consistant on both side of the car
- Check in the wheel arch with your flash light and see if there are any crack or RUST, or any inconsistancies.
- Check all around under the car with your flash light and see if there are any RUST, bent or damaged support rail or any inconsistancies.
- Check all around under the car for any sign of oil leak.
- Check in the boot, remove the carpet and spare wheel and see if there are any major rust (minor surface rust is ok).
- Stick your hand into behind both rear quarter panels (where the car jack are kept) and feel if it is damp or has water collecting in there or rusty.
One of the huge thing to look out for is RUST. Some surface rust is ok since its a 15 year old car, but deep rust with bits flaking off will need treatement urgently and you should stay away from such car. STAY AWAY from cars with a painted bottom (usually black), which maybe an attempt to hide repair marks, or even a 2 car in 1 or 3 car in 1. STAY AWAY from cars if there are clamp marks or unusual gashes on the bottom support rail (straightening machine mark). One thing that I found when I was shopping for my 32GTR is that you HAVE to look at at least a couple different cars and compare. This way, you'll have a better idea of the general condition and whats good and whats not.
I still recommend you getting it independantly inspected by a qualified mechanic if you are unsure.
Edited by __PhaseShiftDown
https://www.sau.com.au/forums/topic/219992-getting-a-gtr/#findComment-3879577
Thats sounds way too low! Unless the previous owner drove it once a year... If not, its been winded back to a rediculous amount which is just stupid and no one would believe.
Has it got a 180km/h speedo (stock)? Only thing to judge by the K's being genuine (but still)
Check out the interior
Listen out for sounds, noises.
Check the gauges, take it for a test drive.
Check out the engine bay with your mechanic. (Prefferbley get a mechanic who works on performance cars)
Ask as many questions as you can, which will make you see how genuine the seller is.
https://www.sau.com.au/forums/topic/219992-getting-a-gtr/#findComment-3879799
Check for weld spots in the engine bay and get the chassis checked out thoroughly. You really want to make sure that if it has been in an accident that the repairs were done correctly (and lets face it; a much higher proportion of these cars have been in accidents than we actually realise).
https://www.sau.com.au/forums/topic/219992-getting-a-gtr/#findComment-3881111
    • I found a supplier for an arm in NZ. https://thrashgaragenz.com/products/nissan-skyline-v35-z33-350z-front-lower-straight-arm-rh-side?srsltid=AfmBOopMdfCFDc_8yVZZ9kq5nIngPHRTBzUU8v4SAptJaRO52Wjs0bC6 I looked closely at the photo of that one and the Z1 arm, and it's the same bloody arm. Scratches all match in the photo 😂 How hard is it to change that joint? Also they seem to be listing two options https://thrashgaragenz.com/products/nissan-skyline-v35-z33-350z-front-lower-straight-arm-balljoint-rh-side?_pos=1&_sid=229acde44&_ss=r And now I have no idea what size I'd need yay
    • Ill review it again, from memory when I first saw some of Trailer Park Boys I wasn't a huge fan. I ended up at Letter Kenny after watching Shoresy, which is a bit ass backward, ha ha
    • "lol dunno" either But like you, I can't see any reason they would need to be different LHD to RHD
    • I agree with you WRT the hard top. MX5's may be one of the better looking soft tops but I cannot think of ANY car, EVER that looks better with a soft top vs a hard top (or a designed roof). At all, ever. I also feel this way about the C5 Vette, the Z06 looks horrible compared to it's original form, it has an exaggerated version of the differences you're talking about.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
