GTST Vs WRX and WRX STi?
depends on what mods and driver ability, i beat a mates rex although in my gts-t, both had exhaust and air filters, mine was boosted to 11psi, but yer havent run a moded one or a sti so cant really say for sure, cant wait to give em a go but ;)
cheers...
www.freewebs.com/2BNVS_r33
WRX will always beat a gtst. Stock for stock or both with the same modifications. As long as the WRX owner can get the best launch out of it and the same for the GTST. It will get closer towards the end of the 400m mark as the Nissan pulls up closer but i think the distance won from the launch will just get it.
STI will beat both FOR CERTAIN.
mite as well post up a
GTR vs GTST vs WRX thread while we are at it.
Originally posted by N/A®
...As long as the WRX owner can get the best launch out of it ....
as we all know, launching a WRX is one of the few simply joys in life.
No other car can accelerate as well as a WRX..after it bogs down
Funny man, I like you! :bahaha:
Try launching an Evo VIII. Makes Rex look pedestrian, nothing from Subaru or STi i've driven (and i've had a go in a few quick Subies, incl a 22B) accelerates from 40-160km/h like the Evo.
By the way, you ever notice Subaru backwards is U-R-A-BUS!
Evo are not that powerful, Sti are not that shit
they are in the same class. In Jap, the Sti is a touch expensive than Evo.(as i remeber)
the WRX is more mature car then Evo (similar performance, but heaps better ride quality) and the Evo is following the way WRX goes(that's why the Evo 7 GTA was built)
i agree Evo is a better car, but it doesn't worth the price different in Aus.
BTW, have u EVER launch a Evo 8?
WRX will eat Gts-t in daily life, coz heaps better traction when they launch
Erm, yes i have driven an Evo VIII. Why?
Evo VIII DOES make the Rex look pedestrian because of its shorter gearing, which means it blasts the 0-180km/h quicker than the WRX STi can.
As for your claim that the Evo is following the STi:
Well that's why Ralliart blatantly copied FHI by putting AYC and ACD on their cars, D'oh! :P
For an STi WRx to get past me it has to have alot more $$ spent than I have.
For one it needs an aftermarket turbo upgrade, intercooler and ECU. Then it may beat me.
Guest StickyIckyIcky
dunno about the evo8 but .. the MY01 STI (bug eye) Vs the EVO7 in BestMotoring V5 they say the STI pulls harder in 3rd and fourth gear..
though the evo holds a tighter line....
Not trying to be a smart ass but, you did mention STI right? Ok, i draged a wrx a few years back at a proper drag strip with the mods you mentioned, turbo (VF 22 STI one), FMIC and ECU. So really it has similar power output of an STI but minus the lower gear ratios = slightly slower car. However, it was on 1.2 bar. I ran a 12.4/12.3/12.8 Consistantly... so really, an STI DOESNOT need a turbo for one, to beat you.
I noticed youre only in the low 13's??!!! By the way, the WRX was a WAGON.
:shake:
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
