G'day folks
Looking to chuck a front lip on my stocky R32 GTS-T front bar. Due to the difference in shape to a GTR bar, I don't think the GTR lip would fit on it, and I don't have the cash to go and buy one for it not to fit.
Has anyone seen any a/m lips for a non-type m bar? either someone selling one, or even a pic of one on a car floating round japan, as I know they were big on factory aero with lip kits back in the day.
Looking to do something like this
Edited by AndrewJZX100
https://www.sau.com.au/forums/topic/220167-r32-gts-t-front-lips/
umm i have one but its not what you think...
it was an auto drop down spoiler, that drops down at 70km/hr....also have a manual down setting.
it ways about 20kg and has 2 actuators attached
the actuators wont fit if you have a front mount...but you maybe able to attach it another way.
PM if you want it still.
Some r32's came from factory with an automatic front spoiler. View the vid below of my car;
You can get aftermarket lips for your front bar (depending which front bar your car has) Although they are made of fibreglass and you will destroy them when you clip a kerb :P
  • 3 weeks later...
Its a TBO lip
i have one on my car that i bought here in Aus, but took me over a year to find it and it was broken wen i got it
still gota have it painted but car is off raod atm
Only place you will get one is Japan and most importers will charge you about $400 - $450 to get it here thats what i was quoted
I was very lucky to find mine in Aus :D
  • 1 month later...
I reckon it is as you can see it doesn't quite match up to the shape of the GTS bar.
I tracked down one of those auto spoilers and fitted it up. It took some modification to fit how I wanted it, as it's not a 100% match to the shape of the bar. I cut a few V's in the plastic so it could be bent into a more angular shape and matched to curves in the bar.
Heres what I ended up with:
And painted:
The paint match isn't quite 100% but I don't really care. I wouldn't mind seeing how it look bogged up to the bar so it looks moulded in, but I like having the ability to take it off if I wanted.
Yidz: Yeah it does sit pretty low :( which is the main reason I like having the ability to remove it if needed. In the first pic, my driveway slopes down on like a 45* angle, and the bit under the car port is flat, which is why it looks so low to the ground (and which is why I'm only halfway into the carport, any more and the lip goes bye bye as it was only cable tied on at that stage :()
GTS4WD: This was one of the motorised lips, until I messed with it :)
And nah they aren't front runners from the drags in the top pic, it's because the stockies have poo offset combined with 3* of camber from Nismo top arms, they sit wayyyy into the guards :)
^ sweet, cheers for that info mate. I was originally trying to find a car that had a front lip similar in shape to the stock bar, then found the 32 came with one anyway :domokun:
Might have a gander at these Accord lips, as I sorta wanted the lip to stick out forwards a bit, which the stock 32 lip doesn't do at all :domokun:
Do you know the model year range or chassis code of the ones that'd fit best?
um im not real up to date with hondas haha but they come off these ones.... you just chop the ends to suit then drill holes in the gtst bumper and accord lip and give it the old zip tie treatment.
514434638_719782d7c2.jpg?v=0
that links a pic of the model i mean. i think the oddysey lips work to coz they look identical to me??
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
