  • Replies 86
the bonnet itself looks real good .... but as if youd waste a perfectly good bonnet on a heap like that .. thats just my opinion,, not really into that colour , and the wheels are shocking !!
does the bonnet make the car go faster ? could you break 11's with the new bonnet ?
Goodbye.
User Banned.
GTRBOS bloody nice GTR. Your bonnet looks like an erect penis in pic #4.
GBTURBOS your white GTR on page 3 is gorgeous. Painted CF bonnets work very well. Love the look :laugh:
Nice work fellas.
MRAK47. You suck.
thank you very much blitz
lmao thanks for the coments r3380y
cheers mate
and i agree wih you there r3380y, users like that do not deserve to be on this forum
Edited by GTRBOS
mate not a bad looking car at all...quite original with the colour scheme..Maybe not the way I would do things but nonetheless pretty good...Wheels look great on it....bonnet screams gettouttatheway !!! Very good
tai thanks for the comment bro, would love to see your car on road bro, cant wait
gtr-32u- cheers mate, i have found some black te37 wheels in 18 but not too sure what the width and the offset is but look very good on this gtr, his after $2200 with non rw tyres,
thanks for the comments guys,
cheers tony
Looks good with that colour :thumbsup:
Very nice :D
Didn't read many of the other comments, but i see your a little sticker on your ash tray cover with the gear numbering on it.
Does someone else drive your car? Or do you forget :D
Very nice :D
owgasm- thanks for the kind comments mate,no with the sticker i got i witht the nismo gearknob and i thought i should just put it there, thanks for the kind comment champ, luv ur car aswell
madevo3- thanks mate, the car pushes about 241awkw@1bar, power is not bad for now, got some nismo 600cc injectors and also the z32 afms going on in about 1 week and maybe a greddy fuel rail but i will see, will change turbos soon aswell champ
Edited by GTRBOS
Haha yeah, i knew it was from the gearstick, but first time i saw it place anywhere besides the gearknob.
Cheers Buddy :D
lol hehe thanks mate ill probably end up taking it off, i dont like it and by the way no-one drives the car bro, its my car haha,
cheers mate
just curious.. why is ur bonnet illegal? (im a mechanic and done millions of r/w's)
never knew that carbon fibre bonnets were illegal...
only reason i can think of in ur case, is ur vent position.. thats it :D
ywer i am chsing massive power mate but just slowly bro, just lent some cash to family but as soon as i get it back i will go all out on it, i got the z32 afms and the nismo injectors for cheaper then normal prices so y not lol,
thansk champ
Its illegal cause carbon bonnets shatter and splinter instead of crumple.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
