so mike the slackeer finaly got the safc wired and the greddy profec boost controller installed......the old girl was wayyyyyyyyy retarded and wayyyyyyyyy rich but now is zooooom zooooooom :D:O:O many thanks to hills motorsport .btw she got a 167awkw run squeezed out of her at 13 psi.which i thaught not too bad
https://www.sau.com.au/forums/topic/220420-finally/
will be running her on 10 psi on the low boost setting and 13 on the high boost setting prob never run it on high as goes good enuf on low. and yes she is stock as a rock in the turbo and exhaust etc departments.im working on the swaybars lol
https://www.sau.com.au/forums/topic/220420-finally/#findComment-3888228
That's awesome mike, >160kw at all four wheels, nothing but an safc and boost controller + tune... haven't even upgraded the turbo :) I'd be running it until I got that ceramic-in-the-cat' problem and use that as an excuse to rebuild the turbo with a gcg hiflow or something... :) then you're just buying some time to save up the $1900~ish in the meantime :)
Edited by DaveB
https://www.sau.com.au/forums/topic/220420-finally/#findComment-3890349
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
