So i've received a fine for under 15km/h which is 75 and 3 points. i think this was in a 50 Zone near anzac parade.
i've only just bought the car within the last 2 months. and it was on the written off regester, the previous buyer bought from auction and repaired it..
and its a diesel, so its surely no performance car at all.
now i've tested the car with a gps since the fine and my speedo is out. by a few km/h up high and a little more down low
would i have a leg to stand on in court representing myself? or would someone suggest a lawyer?
or should i just cop the fine even tho i thought i was doing the correct speed at the time.
the money from the fine isnt an issue, nor the points... i just want to keep my licence perfect :D
Edited by Angus Smart
https://www.sau.com.au/forums/topic/220535-contesting-a-speeding-fine/
to tell the truth, i dont think its there problem if your speedo is out or not... I rekon you will get done even worse if you take it to court... I know it sucks and all but if it was me, id pay the fine, cop the points and fix the speedo... good luck to you if you take it on tho.
Anzac Pde is a 60 zone (mostly) untill you get to Alison road then it becomes a 70 zone all the way untill the end of Sydney Boys high. Obviously during school times the 70 becomes 40 zone.
The section you are talking about which has the camera is on Cleavland Street and not Anzac Pde, along the Sydney Girls side is where the camera is.
It's been there for months and months. Initially (as with all new cameras) there was a "warning issued" to speeders. But I guess that's expired.
The Cleavland street section is a 50 zone. Heck the whole of Cleavland street is 50km/hr.
Maybe you could try and say it's your first fine etc etc and get off it? Dunno
there is already a 10% speed allownace in place with nsw police i belive?
this allows people with speedo that are out with old cars get a way with an amount.
eg:
40kmph your allowed 44kmph
50 allowed 55
60 allowed 66
and so on .........
i dont think cops in nsw book you under the 10% differance, but Vic they do.
What was speed the cop put on the ticket?
He got done by a fixed speed camera..
There are 3 signs before the camera and plenty of 50 zone signs at the sides, even on the ground it marks "50"
I love doing the speed limit there and seeing annoyed drivers tailgating me, coz they think that im going too slow, then over take me and speed up as they pass the camera. *FLASH* haw haw. :bunny:
Happened one night last week... Idiot car behind me was tail gating me.. I trott along slowly... She over takes me (Honda CRV Sport), just as it happen *FLASH* think I was in the flash too but I know I was doing 40km/hr so hopefully I wont get a fine. Otherwise id be pissed, and I have details of the other car anyways.
YOu can contest it, use the law mentioned above which allows a 10% tollerance eithaer way on your speedo, it takes awhile but it will have you with a clean slate.
for starters I'm not convinced that the allowance for speedo inaccuracy is law set at 10% and even it if is my maths tells me that 15km over 50km/h is 30% over 10kms would be 20% over. so unless he was only 5kms over that is not going to hold weight.
He didnt mention his speed, at least I didnt read it .. 15 and under is the lowest speeding fine you can get. I was just giving advice based on this law.. and yes its about 10% but Im not 100% sure.
This 15 and under is crap I think as it holds the same fine as someone doing 15 over the speed limit when he perhaps did 55kmph (which im pretty sure he could not have done as im pretty sure the fact is the the speed cameras flash at 57km/h 12% over road speed) I feel there should be a lower fine of 5k over and 1 demerit point.
In regards to the speedo it need to be calibrated on a dyno, from factory speedos come either to fast or more often than not to slow thats why the 10% leway exists. Oh and this is up to you to fix
Edited by DECIM8
I got done in a work truck, the speedo was out, i thought i was doin 95 but in actual fact i was doin 105. it was a 90 zone, work got the speedo check and found it was out , my boss rang the police or someone told them they changed the fine and loss of pionts but i still got done for 5 over.
You're speedo, you're responsibility unfortunately. And with speeds, generally if it's done by us and not the camara we will put you give you the lower out of the 2, i.e. 15 and under rather than over, with all honesty you don't stand a chance in court. What people don't seem to understand is that a Magistrate can impose a higher fine than the IPB regulates if he feels it is a waste of the court's time, plus you will be issued court costs of $76 for the day, and Legal Representation if you had it.
Better to just pay up and be more cautious next time but its up to you at the end of the day =)
There is a 10% speedo tolerance in the ADR's for vehicles manufactured after some date like 1976 but your information is incorrect. The speedometer can only 10% MORE than the actual speed of the vehicle. So if you are doing 60km, the speedo can read 66km, not vice versa.
Cleveland St has been a 50 zone for years and years. The cameras have been there since last November and there were big flashing messages boards there for 4 months.
No point going to court an saying you "Thought you were doing the right speed". You have to prove to a magistrate that either you WERE doing the speed limit or the camera was inaccurate. Good luck trying to prove either of them I'm afraid.
Its not her fault VTAK kicked in while she was behind you. :yes:
And its a CRV Sport. If it wasn't meant to go fast, they wouldn't have called it a Sport.
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
