Hey guys
how are you all?
Just a question - My Battery in my skyline has just died (it's a japense small battery unit). i have looked every where but it seems to be not available in Australia. The issue that i am faced with is that if i get a bigger battery the terminal arms will not reach the terminal (May have been modified .. not sure) and i dont want to wined up with a battery that want have enough power for the skyline. Would i have to modify the arms or are there batties out the that are specialy made for the R33..
https://www.sau.com.au/forums/topic/220566-skyline-r33-gtst-battery/
Pain in the ass to find them, you can actually trim the terminals to fit any battery with a razor or visit jaycar and buy new terminals.
Alternatively ring Joel at excite autos, Im pretty sure he can help out. Hes sells car and does servicing but seems to stock batteries. www.excitedautos.com.au I think otherwise pm me if you want his mobile.
hes in castle hill
To DIF's comment more often than not the supercheap book will have up to perhaps 89 skylines as in r31 and no more :bunny: Check the company website and I think I picked up mine at bob janes.... edgecliff they had one left
Edited by DECIM8
I replaced my battery few months ago, and it didnt need any modifications.
Was slightly bigger than the original one.
Didnt have to take the rear struct brace bar off either.
got mine from www.sspi.com.au
Give them a call on monday :)
Edited by siddr20
Get larger terminals and replace the old stock ones. Might as well while you are at it replace the wires for the battery. Perhaps move the ground wire to a better ground (as the stock position isnt very good, can cause alternator whine).
ps. Try and get a sealed battery for the R33's since by default they are in the boot. I think it's technically illegal to have a standard non sealed battery if it's in the boot (Aust. standards). Due to the normal acid fumes which can cause an explosion if a spark occurs. (though the std breather pipe should do the trick) *shrugs
To DIF's comment more often than not the supercheap book will have up to perhaps 89 skylines as in r31 and no more :( Check the company website and I think I picked up mine at bob janes.... edgecliff they had one left
The books I keep seeing have 32's & 33's
I obviously goto dodgy repcos.. but they ussually have nothing I want so perhaps your right.
I actually found a up to date book at big w .. go figure.
Ya I'm not a big fan of repco.. Supercheap usually have a few more things but they are all full of people who don't really have a lot of knowledge of the products or what you are talking about >.<
As baron said Kmart aren't to bad for batteries.. they are usually cheap too..
The battery I bought from supercheap bosch gold battery I keep having bad experiences with.
1st one leaked - returned & swapped
2nd one died and wouldn't hold charge - returned & swapped
so I'm onto the 3rd one in less then 12 months.. As soon as the warrenty runs out.. *pending on when this one dies* I think I will be swapping brands.
Hey guys
how are you all?
My original one just died the other week too, went to the Battery Factory and they changed it in about 10mins cost about $120
I had mine replaced for my 33 boat just over 2 months back - NRMA had to come out and replace it with a new one, all good with me, no special battery for me!
I called them too cos it was completely flat so I couldn't drive anywhere... was told they're not allowed to change them in Skylines anymore (or any car where it's in the boot) !!!
He even had to call his boss to make sure he was allowed to jump start me :)
He even had to call his boss to make sure he was allowed to jump start me :bunny:
shell, you do know the jump point for 33s is in the engine bay right? not directly onto the battery. they have special little teminals in the engine bay for easy jump starts. :)
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
