hey guys
im in very sad state of mind after waiting almost a year to get my car on the road iv got a major problem
ok here i go, i had an r33gtr which had a forged motor with a n1 pump, i put the motor into a r32 gtr
all way going well until a couple of hours ago, after my mate finished adding the final touchs to the pfc we took it for a drive got a bout 300m down the road, and the car stalled, tryed to roll start (kick the clutch while moving) all 4 wheels locked up.
at this stage i was very worried, it felt as if the motor seized mind you the motor is only bout 2800km old built by race pace...
so we pulled of the cam and cam gear covers of to see if anything broke,
but nothing but i did notice there wasnt allot of oil on the cams and underneath the cam covers was dry as a bone, so something to do with oil pressure,
i do have any aftermarket apexi oil pressure gauge that wasnt showings any sign of low oil pressure. and didnt here any knocking or breaking sound
the motor was running perfectly in the r33gtr which i use to own, now is a wreck coz it got hit but no where near the motor, i did get a breaker bar and crack the motor every few week to keep everything lubricated, only thing iv changed on the motor since it was in the 33 are hks dump pipes, bigger exhaust, changed plugs,oil and filter
oh and btw my mate is a mechanic and know what his doing when it come to rb26s and will try and get it stripped down tomorrow but i need to know if this has happen to anyone before im very worried and need to sleep at night
some please help thanks guys
mods to the motor are
Forged Pistons (Arias)
-Metal head gasket
-N1 Oil pump
-ACL bearings
-New crank
-Head Work (just general tidy up)
-New belts
-Engine Blue Printed
https://www.sau.com.au/forums/topic/220607-rb26-major-problems/
hey guys
-Metal head gasket
-N1 Oil pump
-ACL bearings
-New crank
-New belts
Does it turn over on the starter with the plugs pulled?
Does your fuel pump prime on ignition?
You have spent a sizable chunk of cash on your motor, why not take it to someone who knows what they are doing before pulling the motor? :P
no the motor dosnt turn over at all, not even with a breaker bar, and my mate is a mechanic that knows what his doing, not his fault engine was running mint for bout 10mins then all of a sudden seized up and locked up all four wheels,
engine is getting pulled down today to find the problem
All injector seals in? drain the oil?
I have no honest idea but I read the other day a person having the same problem with injectors which are not installed correctly and was flooding the engine?
Hydrollic lock i think its called
Edited by DECIM8
im over this car, i was so close to stripping it down and selling it as parts,
but my mate didnt have time to pull it apart today but will early next week, but looks like i will be folkong out for another build,
but the funny thing is we never hear nothing break, and also no metal shavings when we drained the oil
it might seem like a dum question, but when you started for the first time did you take the oil cap off and make sure the cam lobe you can see from there had oil on it????
was the correct seal used on the N1 oil pump?
cause if a breaker bar wont turn it over you have either got A: a siezed motor B: a dropped valve or C: dropped a big end cap?
but from what you described above i wouldnt be surprised if the main bearings have spun and it the cradle pressure clamping the crankshaft.
good luck with that one bro, i feel for ya...
atleast when mine stopped going you new what was wrong with it cause number 3 piston was hanging outta the block.
for it to sieze solid and not make noises, it will of spun a main bearing. the cambelt will snap at the wieght of the whole car. if its just the head siezing, its a pretty damn strong belt!!
so no oil in the head.. all of a sudden. somethings blocked. does it have an oil cooler with remote filter?
the belt isnt snaped, i dont have an oil cooler or remote filter but i did notice there was thick gunk underneath the cam covers but not really any oil there, from what i can gather i think the oil pick up is blocked but wont no until we pull it apart,
if the main bearing is spun will it of damaged my crank? or will i just be able to replace the bearings?
anyway thx for this guys im pretty stressed out atm
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
    • He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
    • Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
